Lower front spoiler/splitter
Re: Lower front spoiler/splitter
That is interesting, the side bits on mine are identical and fully painted as if they were part of the spoiler kit, certainly no sign of ever being damaged
Maybe a previous owner decided to tidy them up? I can assure you the genuine spoiler is a one piece, wrap around affair....
That does sound likely, I am finding quite a few things on the car that have been made to look intended but are not quite right
If I reply one more time I can post a picture, see what you all think
Pop some pictures up, we’ll identify what’s right or wrong
(Or drop me a PM, and I can host up the pics)
Sorry peeps, bit of a noob here, tried pm but can't see any options for adding image?
hit post reply, then just above the white box theres a row of icons - its the one like a box with the outline of mountains in it 3rd from right
Yes, do that and get image tags
Edit: Jiff hosted
Edit: Jiff hosted
Yup, the picture needs to be hosted first.
Drop me a PM
Drop me a PM
Yep, broken end of spoiler, just as explained above.
It doesn't come in sections like some but all one piece, so those bits would need to go to fit a replacement.
That's perfect, thanks all for your help, I really thought they came in sections as both sides are identical, just a bit of a clever cover up job.
You're welcome - you'll always find help on here with any questions...
just for information the 'captive nuts' inside the front bumper will probably still be 'captive' but will rotate.
makes for an intersting arm bending to get a pair of mole grips on inside and sufficient purchase outside to undo them
