Front speakers
Front speakers
Hi all
I would like to revisit the issue of speakers in Skip. I have sound coming at the rear but nothing at the front. The radio seems to be properly connected and I have tried Balance Fader etc but without luck. The connection to the speaker on the driver side seems awfully loose but it does not explain why there is no sound coming from the left I guess.
I will give Skip a decent radio later on with Bluetooth and all that but should I end up wanting to change the speakers are they a common size? I did read 5.25inch but I did also read tat there might be a compatibility issue with the tweeters. I am not an electrician so maybe I am missing the elephant in the room
Help
Help
Re: Front speakers
I think 13cm or 5.25 inches are fine. When I replaced mine replaced the tweeter too, I think all after market 'component speakers' include both. I from memory the volvo is unusual in as much as the tweeter just runs directly from the woofer without using a crossover (which splits the high and low signal) which would probably be the 'compatibility issue' you mention. I'm pretty sure I took the easiest way by replacing both- although I did just get my garage to fit them, I dont like the look of getting the tweeter out!
Good luck!
Tim
Good luck!
Tim
Re: Front speakers
Yes, this is what I was referring to about "compatibility". It is true that speakers have evolved, so if I buy 3-way speakers I need to disconnect the tweeters on Skip? There is no connection from the back of the radio and it all go through the speakers?timrosser wrote:I think 13cm or 5.25 inches are fine. When I replaced mine replaced the tweeter too, I think all after market 'component speakers' include both. I from memory the volvo is unusual in as much as the tweeter just runs directly from the woofer without using a crossover (which splits the high and low signal) which would probably be the 'compatibility issue' you mention. I'm pretty sure I took the easiest way by replacing both- although I did just get my garage to fit them, I dont like the look of getting the tweeter out!
Good luck!
Tim
Re: Front speakers
You will find the sound the tweeters are able to produce will be limited by their size so although it would be preferable to have a crossover, they will have natural physical limitations.
As far as connect or disconnect the choice is yours. I have just fitted some new speakers and connected them mainly because they are there. For appearance I still have the DC942 so that itself will limit things.
No sound from both front speakers suggests the head unit, especially if connections are good. If you are not able to swap around the connections at the rear of the unit to feed the front speakers to the back you could test the line with a 1.5v battery. Identify the two connections to the speakers connect one to the battery and then very briefly tap the other on the battery, do the speakers go pop, if they do it again points again to the head unit.
Only other thing is do not buy the cheapest speakers. I opted for mid range, they lasted one journey and are now in the bin. If you use the tweeters you can opt for two way speakers which hopefully will be of better quality, after all if you look at the size of the proposed third driver the chances are you cannot hear it.
Its the usual, buy cheap buy twice.
Regards
Regards
Re: Front speakers
If I buy 2-way speakers, the original Volvo tweeters will connect to the new speakers? Is the connection: Radio to speaker to tweeter?Espada wrote:You will find the sound the tweeters are able to produce will be limited by their size so although it would be preferable to have a crossover, they will have natural physical limitations.
Regards
If I buy 3 way speakers I can ignore the Volvo tweeters completely? Is the connection: Radio to speaker/tweeter?
OR
Are the tweeters connected to the radio?
I was doing some research based on size and "ways", it seems that the 3-way option has got 4 connections but I am not certain:
http://www.pioneer-car.eu/eur/products/ ... F3_way%3D1
Apologies for all the questions I cannot find wiring schematics
Re: Front speakers
You can connect the tweeters to both the two and three way speakers, both will be fine.
My observation on using two way speakers is that unless we hack the door to fit larger speakers, we are limited to 13cm (5.25"), basically why pay for the third speaker if it is too small or high pitched to hear it.
Hopefully a two way speakers at the same price be be of better quality than three ways.
Connections will all be in the door and four connections at the rear of the speaker will be very useful as this means there will be two + and two - connections. Connect the cables that feed the speakers to one set of + and -, then connect the tweeters to the other + and - terminals.
The original speakers fitted by Volvo had four spade terminals, so copy them and you will be fine.
Regards
Regards
Re: Front speakers
So, 2-way speakers and the original tweeters connected to them. I recall 4 connectors at the rear of the Volvo speakers.Espada wrote:You can connect the tweeters to both the two and three way speakers, both will be fine.
Regards
One last question, the 2 fixing screws are standard, they will fit into new speakers, right?
Re: Front speakers
2 way speakers with the tweeters connected, yes fine.
The other added bonus of two way is that with less items protruding in front of the speaker, there is more chance of the original grille fitting without modification to the panels.
Fixing screws by keeping the speakers the same size as standard they should all line up. I say should just to be cautious but see no reason why they will not. The fixings provided are very universal.
Regards
Regards
Re: Front speakers
Damn, I cannot see 4 spades at the rear though:Espada wrote:2 way speakers with the tweeters connected, yes fine.
Regards
https://www.google.co.uk/search?q=TS-G1 ... RbBFUL8sNM:
Re: Front speakers
if you need extra terminals. Just replace the standard spades with piggy backs and job done.
Re: Front speakers
Can I solder the 2 "+" together and do the same with the "-"?
Re: Front speakers
Got this job to do myself.... looks like I'll be doing a how to!
Re: Front speakers
I think I found what I need.
Bearing in mind I am not after mind-blowing performance this Clarion set has 2 "+" and 2 "-" so it would happily replace what I've got: https://images-na.ssl-images-amazon.com ... SX355_.jpg
Unless I am missing something these are the ones I will go for...........
Re: Front speakers
These will work just fine ,with the four connections it will save you having to join the cables as they will just plug straight in.
You have also noted the rear speakers only have two terminals, remember the second pair in the front are used to power the tweeters, there are no tweeters in the rear so you do not need to use the spare terminals. However ,should you require extra terminals the piggy back connectors suggested by Athuy will be the easy solution
But don't forget that the front speakers currently have no sound, prior to changing your speakers do try and sort this first .
Regards
Regards
Re: Front speakers
PerfectEspada wrote:These will work just fine ,with the four connections it will save you having to join the cables as they will just plug straight in.
Regards
The entire assembly on the driver side (where the spades are) is loose so I might as well install the new pair and get Halfords to replace my existing radio and fix the no sound issue.
Re: Front speakers
Trust ye not the Halfords half-wits.
Re: Front speakers
Not much choice around herejamescarruthers wrote:Trust ye not the Halfords half-wits.
Re: Front speakers
Quick update.
Skip's front speakers were definitely shot. I replaced them with a pair of Clarion SRG1313 and the sound is very very good On top of that they are designed to work with external tweeters so this set is really a straightforward swap.
And there is a pair on Ebay for £25 right now: http://www.ebay.co.uk/itm/CLARION-SRG13 ... SwbIRZbO7T
Have you got the specs for the rear ones? I fancy a change as well.
Best
Moi
Best
Moi
Re: Front speakers
Good people?
Have you got the specs for the rear speakers?
Moi
Moi
Re: Front speakers
For rear speakers you mean the ones in the side pannel of the cubby hole ones?
I have the cubby hole setup and when it came the time to replace them I found they're specific measure for the hole. No manufacturer makes an aftermarket replacement for them. I managed to fit after some DIY, and some isolating foam to cut vibration of the cube, this ones.
https://www.amazon.com/Kicker-40CS464-4 ... B00BGRMFD6
On the front I have a separate tweets setup with this set
https://www.amazon.es/Alpine-SXE-1350S- ... B0000WS0N2
Sound is overall much better than the originals. Remember as well to add isolation foam around the speakers in the door card and the door gap to cut vibration of the door card and the door side pocket
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
2012 Seat Exeo ST
