Yo!
Jackie's 440 just failed the MOT on the horn not working.
Now then,I have checked fuses and wiring and all seems ok there.I dont have a relay cover showing which is which so I swapped relays around which were the same part number and no difference.
The garage also failed to find the fault,but thanks to those muppets we have an SRS light permanently on,but Im just taking the bulb out there,like with my car!
Anyone got a clue??Horn does work on my car when plugged into it.
Fookin thing!
Horn not working on 96/P 440 LE
I'm No Longer Here :(
- ReVolvoLution
Thanks Rolio!
So I assume I disconnect the battery as a precaution and remove the airbaggus???
I did tell her to ditch that shitty plastic palm-ache-inducing thing for a Momo!
Hi Tommy!!!!!
Yes we did,we had to completely re-wire the thing!
How are you over there!???
Steve.
MSN catgroom@hotmail.com
Steve.
