Broken locking wheel nut...help please!
- JohnTurbo
k...know how to get wheel nuts off which are sheared....well my locking nut's crome vanadium 'key' part has broken...is there a way to remove the wheel+disk without undoing the nuts?
Any other ideas?
Any other ideas?
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
- Ally
I've managed to get locking wheel bolts out by nudging them round with a chisel (being careful not to hit the wheel )
Kind of depends on the type of head on the bolt whether this works or not.
You could always weld the head of a 19mm bolt on top and use that to remove it...
- JohnTurbo
Well i was drunk when i wrote this, so it wasn't very clear...the separate key part is fine....its the chromevanadium tip of the actual wheel nut which broke....stupid of me to use the work key...k...know how to get wheel nuts off which are sheared....well my locking nut's crome vanadium 'key' part has broken...is there a way to remove the wheel+disk without undoing the nuts?
Anyway got some "locking wheel nut extractor" sockets on order...left handed taper thread...
cheers tho.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
I can't remove any of the locking nuts because volvo keys are fucked and slip off.
I'll try the http://www.tooled-up.com/Product.asp?PID=109639[
John where did you get your removers?
ok, i know this is late but its another good way to remove a broken locking nut.
i had this happen to an 850.
basically start with a small drill bit and drill through the middle of the bolt, then increase bit size and keep drilling the hole. when you get to a size that is near the size of the threaded part of the bolt, dont go all the way down. keep going bigger until you take the head of. you can then get the wheel of and get a good grip on the remaining stud/stump.
very simple and easy-ish process that wont damage you rim if done carefully.
note: hardened drill bits will help, and be liberal with the cutting fluid.
Volvo 850R Auto, Rica ecu, 13 Row oil cooler, 13 Row ATF cooler, 18T @ 18psi, 302mm conversion, Ferodo DS2500, Superblue Brake Fluid, SS lines, Reverse IC, 20 psi VDO Gauge, previously a silver 1.7 n/a 480es.
in my case i did try that but would not grip onto the volvo ones as part of the outer wall had come off and the socket couldnt grip, also could get the socket deeper back onto an unbroken part as the bolt hole was tapered.martinholmesuk wrote:or a socket (hex) to the same size as the locking nut, hammer in and undo.
did the 480's use genuine volvo locking nuts, or the 3 hole things you get from the market?
