starter motor spade connection
JimAitken
Post by JimAitken » Wed Nov 01, 2017 1:45 pm
Just picked up a new starter motor from EuroCarParts (recommended from my number plate). On the new one, there is a spade connection, but on my old one, there doesn't seem to be one. What should be connected to the spade connector? Is it used on a 480 2L?
thanks
Jim
current: 480GT, V70 D5
previous: 480Turbo, 440, 850, V70 Classic. Renaults 4/5/6/20, Mini Cooper S (1968), Alfasud ti
Re: starter motor spade connection
Post by jifflemon » Thu Nov 02, 2017 7:47 am
Do you mean the new starter has a second spade connector? If so, ignore it. It's used in ballast resisted ignitions on much earlier (and also non volvo) cars.
JimAitken
Post by JimAitken » Thu Nov 02, 2017 1:51 pm
Yes it's on the new one. Thanks for info. I'm going to swapping the starter motors over this weekend.
cheers
Jim
