Hi all
Yesterday I could "nearly" remove the rear seat (the bum bit) but they remain attached in 1 corner near the rear central console, Would you happen to know how I can remove them completely? So far I have found 2 pens, 50P and strangely enough a WW2 German insignia (!!!)
While I am at it, how to remove the backrests
Best
Moi
Rear seats removal
Rear seats removal
Re: Rear seats removal
The seat cushion (bum bit) has a twisty wire on one side - wiggle the cushion around at different angles and it should come out quite easily.
The back rest has a black plastic locking piece inside a metal bracket on the side of the car - you need to use a narrow screwdriver to gently push the top of the upright aside to release it. This is what they look like:
Couple more shots.....
Twisty wire in situ....
Bum seats front clip in place
Bum seat front clip removed
- 480s partner
How did you push the bum seats front clip through (that rectangular catch)?
The clips on mine are slightly bent outwards and I feel no human force can flatten them to slide upwards.
Hello
I used my fists as "persuaders", it will go in eventually
Push the clips back and upwards using something like a large screwdriver; they are supposed to stick out slightly as you describe - just needs a bit of force...480s partner wrote:How did you push the bum seats front clip through (that rectangular catch)?
