A few advisory notices though.
Minor Corrosion to rear brake pipes.
Rear Discs nearly worn (Already aware of that)
Minor leak in P/steering system
Dipped-beam too low:shock:
Nail in a tyre
Minor play in F/N/S balljoint
Oil leak in engine (already aware & its minor, or normal for one with 144K!!)
AND
Excessive play in F/N/S wheel-bearing.
Now with this last point he asked me if it had been me that replaced the front discs (I did about two weeks ago). He then said that I had not tightened the bearing up when refitting & that it is part of 'the job'. Now in 'paynes' it does not mention anything about the bearings in the how-to replace discs.
In the bearings 'how-to' bit it says if play is excessive to replace.
So does anyone know if the bearings can be simply tightened. I guess, if yes it would be a simple case of wheel off (axle-stand) & tighten the big nut in the centre of hub?
Still, I'm chuffed to nuts with the pass!
![Hopping Happily :hopping:](./images/smilies/hopping.gif)
