Loss of Power when engine is hot... fine when Cold
Re: Loss of Power when engine is hot... fine when Cold
Post by jifflemon » Fri Aug 06, 2021 10:44 am
Didn't Ade have something similar and it turned out to be the injector seals?
Rob88h
Post by Rob88h » Sun May 22, 2022 7:42 pm
Hello Shane. Did you resolve this? I’ve got the same problem (or should I say symptoms!) with my 440 1.8i and have gone down a similar diagnostics route with no luck yet.
