Post
by Alan 480 » Tue May 31, 2016 11:51 am
480s partner wrote:Hope I am not asking a dumb question, but can I activate-test the pump as of now, like this (outside car, no coolant)?
I have a power supply unit of DC 12V (or 13,8V) up to 5 amps/ 7amps peak available, would it just be a matter of making the connections and see if I get response?
a quick run off a car battery will do no harm BUT as the seal is 'lubricated' / 'cooled' by water dont run too long.
to check if leak tight you could attach a long length of garden hose to it and fill with water and top of hose on second floor will give a decent 'static-head'
480s partner
Post
by 480s partner » Tue May 31, 2016 6:35 pm
480s partner wrote:
Haynes manual keeps reffering to an elusive cylinder block drain plug "located below the inlet manifold near the oil pressure switch"...?
I may have found it!
I suspect this is the one:
Picture was taken from above with cell phone with screen facing bulkead/camera facing back of the engine.
There seems to be a plastic or rubber washer between the plug and the block, so surely this can't be used for oil, right?
480s partner
Post
by 480s partner » Tue May 31, 2016 6:37 pm
Alan 480 wrote:480s partner wrote:Hope I am not asking a dumb question, but can I activate-test the pump as of now, like this (outside car, no coolant)?
Thanks Alan, I will give it a try.
480s partner
Post
by 480s partner » Wed Jun 01, 2016 7:31 pm
I made a little experiment today:
Suspended the pump, attached some hoses (one connected to shower
)and let the water run through for a few minutes.
When I turn the power on there is a small boost in water flow.
So, pump is working and apparently there are no leaks visible!
Post
by jamescarruthers » Wed Jun 01, 2016 7:54 pm
Impressed, well done!
Post
by Alan 480 » Thu Jun 02, 2016 11:37 am
480s partner wrote:I made a little experiment today:
now connect the shower head to the outlet and you have a 'power shower' ?
mathrock
Post
by mathrock » Mon Jun 03, 2019 1:25 am
480s partner wrote: ↑Mon May 30, 2016 10:03 pm
Ok, new ring is in place and cleaned surfaces mate perfectly.
I know this is an old post, but do you happen to know the o-ring size you used? The aux water pump on my 1993 turbo is leaking in the same spot yours is and I'd like to order a replacement to have it on hand before taking it out.
Thanks!
