knocking sound from the front.
- martinholmesuk
fook!
Mine has started to make a knock from what sounds like the front!
I drive off and it bangs then nothing until I slow down or pull off really quick.
Ideas?
Ideas?
Audi TT
Audi TT
- dragon
- Volvo 480 Club Europe CREW
I'm going to state my normal "odd knock noise" suggestion.
Engine mount. Front or rear? Well that's for you to find out, but I suggest the rear.
Gaz Wilson
Gaz Wilson
- martinholmesuk
- martinholmesuk
- martinholmesuk
- guitarcarfanatic
Haynes suggests a worn CV boot or joint if it is a knocking at slow speeds.
This is haynes though...
Rob
Rob
Previously...
1989 Black ES - Great runner
Previously...
- Agwa Moose
- 480 Veteran
- martinholmesuk
Both ball joints are good, I checked when I replaced the wish bones. They also look ok.
Another rear odd thing is..... and it's going to scare me....
when I pull off it feels like the hand brake is on. It's like the car is being held then released. Evil force maybe?
Audi TT
Audi TT
- chris1roll
- Agwa Moose
- 480 Veteran
Mart,
Just finally sorted out my knocking,so thought I'd post ASAP for your benefit mainly.....
Just took both front wheels off.Okay,everything I had done up tight when all parts were fitted.
1 week on......both strut bolts-loose,both sides.Top mounts-a little bit loose.Ball joint nuts/bolts to wishbone-very loose!!!!!!!Anti roll bar links-haklf a turn loose!Ball joints-okay funnily!!!!
I would check again mate.
Good Luck
Groomus Grinnus!
Good Luck
Groomus Grinnus!
I'm No Longer Here :(
Bedding in,Mr.Murphy....
Y'know that thing you Uni students spend most of yer degree years doing
Re: .
Very good Groomiester.catgroom wrote:Bedding in,Mr.Murphy....
Ah those were the days huh?
Stu.
Re: knocking sound from the front.
I've now exactly the same problem.martinholmesuk wrote:fook!
Ideas?
It think it's an engine mount, however I couldn't undestand if it was the rear engine mount or the front right engine mount.
That noise makes me crazy afte 10 seconds in city with window opened...
