ABS UNIT VALVE OVERHAUL KIT
I was recently informed by a forum member that you can overhaul the valves in the ABS unit.I was pleased,as a new unit is pushing 1200 quid from Volvo now!
So,can anyone give me the part no. Volvo list so I can avoid any bullshit from em when I call them?Using the Tardis,naturally!!
Oooh,I will be overhauling both of my units so will have one spare soon for sale.....
Oh,and one other thing-I would expect the unexpected when the ABS light comes on-the brakes lock up after a good few miles of the ABS still working!!!!!!
I wonder if the braking reverts to that of a normal system when it packs up too,or whether there is more dodgy stuff going on under that bonnet due to the ABS malfunctioning.....
I'm No Longer Here :(
- chris1roll
If the ABS malfunctions, signified by the ABS light coming on, you will have normal non-ABS brakes, so they'll be just as good as those in a non-ABS car. Still fail the MOT though.
If however the fluid warning lamp comes on - you may not even have that, and should stop!
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
@Fargo Which country are you in? I would be interested in having my units overhauled......
@Chris Would it fail the MOT on the rolling road brake tester???If its just the light being on on the dash,I'd just take the bulb out-just like Ive done for the SRS,ummm,and all of the other bulbs actually!!!!!!!!! Anyone want a spare dash bulb then??!!!!!!!
- chris1roll
Re: .
Hi,catgroom wrote:@Fargo Which country are you in? I would be interested in having my units overhauled...
I'm in Hungary.
I can't tell you much about it right now because I'm just off to visit my parents, but I'll be back by Saturday latest, so that I can tell you the details...
Cheers:
Istvan
480 Turbo, '93, White
- Murf
depends where you get it tested. my dads 440T has an abs fault,every year at mot time, he just takes the bulb out and it passes.If the lamp doesn't come on when ignition is switched on initially, it will also fail.
Especially since one look under the bonnet will tell the tester the car has ABS.
you'd have to be pretty interested to check that the car had ABS when its not that obvious, i dont think many places have the time/inclination to check.
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
