First of all, huge thanks to all the people who have posted on this forum. I would've probably scrapped my 480 within the first year of ownership if I didn't have this forum as a resource to turn to.
Anyway, after three years I've faced what seemed somewhat inevitable: pop up motor trouble.
I took away both motors and tested them. One of them seems to be unfunctioning. The working one seems to work on both sides.
I'm guessing its a ground problem (?) because it occasionally worked when I tapped it, but then refused to work alltogether. The whole pop up motor is encased in some sort of plastic, but some of this shielding case has cracked. Am I correct in assuming the earth wire is this one:
https://photos.app.goo.gl/3QGzqcjHVD0Xmm3E3
If so, would it fix the motor if I simply grounded that with another wire? Or could it be fixed by someone more of a competent car electrician than me?
I'm utterly lost when it comes to car electrics, so I come here (again) to look for advice.
Thanks for the replies in advance!
Regards
Filvas
(Owner of one of only 14 Volvo 480's in Finland)
