hiya, i have a b18ft, i no there are a few differnt posts about uprating parts on these, but i am unsure still.
firstly injectors, ive read about yellow cosworth injectors, or v6 volvo injectors, are there any that are the best to go for??
also 3 bar map sensor, do they just bolt on and plug in?? will i need a super mod ecu for it to make a differnce?
and the turbo, these engines come with a t2 turbo standard? so a t25 or a t28 would be fine to upgrade too?
thanks scott
B18ft
you need to match the injectors Ohm value = 15.4
the 740 has thoose 230 cc against 170 orginal b18ft
a t25 or t28 is ineed an good upgrade. next time in would buy me an gt25
Richmod can stil be done, last time i was on the dyno it gave me 161 BHP and 230 NM @ 0,7 bar.
Now i am running @ 1bar, need to go on the rollers soon again![Very Happy :D](./images/smilies/icon_biggrin.gif)
Renault 5 GTT *volvo 480 turbo power*
161 BHP & 230 Nm @ 10 Psi -->Now running on 18 Psi :P
soon --> new engine in with 315cc injectors t25/28 turbo an BIGMOD :)
yr 5 is mint mate. im runing simaler set up to u.
but i keep munching clutches
only running 0.90 bar
wat clutch u using??
[img]http://img.photobucket.com/albums/v485/badboi106/sigs/daver5new.jpg[/img]
renault shell, custom cage, no dash, volvo engine, nissan turbo, apexi boost controler, ksm re-wire, persision automotive down pipe, dta engine management to come. 175 BHP 220 LB/FT torque
ring me for parts 07805391168
