Genuine Volvo stiffer springs!
This information may appeal to you if you dont want to lower your car,but would like improved handling through stiffer springs.
A mate from Volvo-Tech forum has kindly offered to send me info by post on the different colour codings of Volvo springs.
He has just informed me that there was 6 different types of spring for the 440/460 fronts,which fit ours.There are also 4 types for the rear.These springs are all colour coded and correspond to a chart which I will post once I receive it mid next week.
Could be summit for some of us here?
I'm No Longer Here :(
- VanDerGraaf
Nice work Groomus!
Have been wondering for ages now about that colour coding.
08 Renault Laguna III Sport Tourer 2.0T 4 wheel steering madness
00 Citroën XM ES9 V6 incredible
Previously:
00 W210 Mercedes E430 V8 estate LPG .....wünderbar!
00 W210 Mercedes E320cdi estate dead, eaten alive
95 Citroën XM 2.5 TD estate dead
95 Citroën XM 2.1 TD stolen/dead
'97 Saab 9000 Aero gone
Vase Green '94 Twin Pipe 480 Turbo
"Scar", Vase Green '94 Turbo dead
"Green Goblin" '93 Turbo Auto PITA, dead
Grey '88 ES dead
Steel Grey '93 480 Turbo sold and believed dead
Previously:
Grey '88 ES dead
From memory of the phone convo,Red is the stiffest at 21 nms.Black is the softest at 12 nms-boing!
For the front theres grey,red,blue,yellow,green and black.Rears were black,red,green,yellow IIRC.
Im guessing Volvo prices will apply,naturally!Not sure who made them for Volvo though.Maybe Mr Foxus would know this,being a production line zombie
Iam in no way suggesting that the Volvo staff had been indulging in some of James May's bus driving soothers!
- VanDerGraaf
I read somewhere that it was Lesjofors that made them?
Previously:
Grey '88 ES dead
Previously:
Grey '88 ES dead
OK received the info today on these springs so ere goes!
Fronts
Colour Code Black ie No Markings-:Spring Stiffness-:17nM Length-:372mm
Blue 20 360
Green 17 362
Yellow 20 350
Grey 12 457
Red 22 355
Rears
Colour Code Black ie No Markings-:Spring Stiffness-:19.7nM Length-:322mm
Yellow 17.2 310
Green 14.7 350
Red 21 289.5
All springs come with a paint marked line approx half way up for ID purposes!The whole springs luckily dont come in Grey or greenus!LOL!
Theres more info if you need it but I posted the 2 most relevant specs for you all.
Happy boinging!
Steve
Fronts
Blue 20 360
Green 17 362
Yellow 20 350
Grey 12 457
Red 22 355
Rears
Yellow 17.2 310
Green 14.7 350
Red 21 289.5
Happy boinging!
Steve
- clubman_dan
would the ones with a shorter length lower the car?
'05 Skoda Fabia Vrs- diesel power baby!
'91 turbo oyster grey- full leather, momo wheel, aircon- SOLD
'94 turbo, metallic black- Scrapped
'95 2.0 es SOLD!
'86 mini 1380 rather fast!!
[url=http://www.sloganizer.net/en/][img]http://www.sloganizer.net/en/image,clubman-unl-dan,white,black.png[/img][/url]
'95 2.0 es SOLD!
- chris1roll
Steve, is that what volvo actually told you?
I'm not sure they would, as the shorter ones are actually stiffer, they will compress less when the weight of the car is on them resulting in the same ride height overall, I reckon.
Just curious....
Actually.... looking again, it would appear that yellow would be 10mm lower than blue as they have the same spring rate.......hmmm, But then the grey wouldn't be 100mm/10CM higher than blue cos they are much softer....
Job for someone who can be arsed to work out the spring rates/length and preload?
Some of this would also be affected by the condition of your shocks too, so rebound would come into it?
Just curious....
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
Hi Chris!
As said over the weekend its what Sarum Boy from Volvoclub.org sent me.
He copied the information from Volvo Tech Data.
Cough
Steve
Cough
Steve
- Ettore Bugatti
Sorry too drop in this old topic.
Too work out how much the deflection of the springs are, You should know the lower wishbone length, the distance from the wishbone pivot and atachment of the spring and the angle of the spring.
Search the web on wheel rate and installation ratio for calculations and better explaination.
Rover Mini 1000, june 2009-
Great !
This helps insight very much!
Hey and what is the problem with digging up old topics?Is it against the 480 law or something?
Greets!
Steve
Greets!
Steve
- Williewammes
- Ettore Bugatti
Check these links:
http://forums.vwvortex.com/zerothread?id=2094272
Analysis of VAG suspension
http://www.optimumg.com/tech_springsdampers.htm
Everything you want to know about springs, dampers and handling
Hi Matt ya blonde bastard,from the future!
No problem mate.Sarum Boy from Volvoclub.orgy had go this info from his main dealer and copied it so I passed it on.Not sure if anyone will use it,also the costs of these springs are typically Volvo I expect!
For those wishing to upgrade using genuine Volvo parts (TMus!) these should be right up their junction,alley,boulevard etc!
- Ettore Bugatti
I read on a other Volvo forum that the yellow springs are used in the Volvo sport suspension kit. (sportsline)
The black ones are standard
grey for heavy load (towing)
but Rpruen has also an orginal Volvo kit with blue springs!
http://volvo480.dragons.org.uk/forum/vi ... php?t=7364
