right hand door hinges volvo 480
I am after top and bottom hinges off right hand door. I know they will probably be worn but i will get new pins made. Does anyone know if same hinges on 440/460.
Re: right hand door hinges volvo 480
I think they're the same on 440/460 - I'll check for you tomorrow.
Hi
Have somewhere in my treasures , new and used , must find
Lucky you , found one new / 3472964 / and have 2pc. used , upper and lower are the same . Used are on a car , need time to remove .
As far as I can tell by visual comparison, 440 460 and 480 hinges are identical.
Yes , the same part number .
I’m pretty sure I got new pins from the Volvo dealer a few years ago as the pin is used on many other Volvos.
Hi
Did you get it ?
Did you get it ?
Found these in the garage, part number 3416207 and ordered within the last few years.jamescarruthers wrote: ↑Sat Oct 01, 2022 5:22 amI’m pretty sure I got new pins from the Volvo dealer a few years ago as the pin is used on many other Volvos.
It is a pin for door stop
Ah, yes of course! Thanks Mareck!
