Wanted: seat belt holder, window regulators, temperature sensor (water) and rear tail lights
GCooper
Post by GCooper » Wed Aug 24, 2022 1:49 pm
Time to get to work fixing the 480 up I reckon...
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
GCooper
Re: Wanted: seat belt holder, window regulators, temperature sensor (water) and rear tail lights
Post by GCooper » Wed Aug 24, 2022 1:50 pm
To add to this, the right DRL has a crack on it
'98 BMW Z3 (daily)
Post by jifflemon » Wed Aug 24, 2022 3:24 pm
Tails lights from the french car club. Its the only serious solution
Seat belt holder? The pop out ones? Which side?
There's 2 temp sensors (one for the gauge, one for the ecu), also which engine?
Window regulators - There is a repair kit you can 3d print
GCooper
Post by GCooper » Wed Aug 24, 2022 7:03 pm
The right hand seat belt holder and the sensor for the gauge. It's the 2 litre engine
'98 BMW Z3 (daily)
Post by dragonflyjewels » Wed Aug 24, 2022 7:17 pm
There is a drivers side seatbelt holder up for auction on ebay at the moment.
GCooper
Post by GCooper » Thu Aug 25, 2022 5:10 am
Thanks but it's the bit at the end of the holder I need and it appears to be missing
'98 BMW Z3 (daily)
Post by dragonflyjewels » Thu Aug 25, 2022 7:28 am
If the bottom part is missing, check your top section to see if the connecting lug is intact. That's what usually breaks, hence the top sections were supplied by Volvo without the bottom part. Usually that's left loose but still threaded on the belt.
GCooper
Post by GCooper » Thu Aug 25, 2022 1:24 pm
The missing piece is the bar that holds the seatbelt in
https://imgur.com/a/U5SLFNr
'98 BMW Z3 (daily)
Post by jamescarruthers » Thu Aug 25, 2022 1:27 pm
You lucky b*****d! :wink:
Post by dragonflyjewels » Thu Aug 25, 2022 2:08 pm
aha, so all that's missing is the roller. Just so happens I have a spare - pm me your address and it's yours
GCooper
Post by GCooper » Wed May 03, 2023 3:40 pm
Tail lights and seat belt holder acquired... Can anyone help with windows regulators, temperature sensors (X2?)
High priority: indicator stalk, cooling fan switch
Maybe needed: b18 edit: B20 engine
'98 BMW Z3 (daily)
Themasteryeti
Post by Themasteryeti » Wed May 03, 2023 7:21 pm
For Drl lenses I got mine from this guy! https://m.facebook.com/groups/564695983 ... &ref=share
1973 vw beetle
1993 480s
GCooper
Post by GCooper » Wed May 03, 2023 7:33 pm
Thanks! Already bought the drl lenses and tail lights from him though
'98 BMW Z3 (daily)
Post by dcwalker » Wed May 03, 2023 7:49 pm
Maybe needed: b18 engine
Confused - you have a GT, why do you want a B18 engine? It's a B20F in a GT.....
GCooper
Post by GCooper » Wed May 03, 2023 7:54 pm
Of course :wall: I'm very tired :D
'98 BMW Z3 (daily)
Oscar WS
Post by Oscar WS » Thu May 04, 2023 4:08 pm
I have the fan switch and the indicator stalk. NB They’re both from an early 480 (‘87 ES) so the switch is for heating only, with the ‘off’ position. Switch is available now but you’ll have to let me know if you want the indicator stalk, it may be a couple of days before I can remove it.
Current: ‘95 Celebration
First love, from new, (now donor car): ‘87 480 ES
GCooper
Post by GCooper » Thu May 04, 2023 6:05 pm
Ah I see the confusion, the switch I need is that one that turns the radiator fan on when the coolant gets too hot, at the moment the fan is disconnected because the radiator fan was stuck constantly and drained the battery.
As for the indicator stalk, yes please! The indicators stopped working but the hazards still work and a quick Google suggested a new stalk would help.
Thanks.
'98 BMW Z3 (daily)
Oscar WS
Post by Oscar WS » Thu May 04, 2023 7:06 pm
OK, buddy. Give me a day or two to get the stalk off (I’ve got a dodgy back, poor old bugger ;) ) I’ll pm you when I’ve got it, to get your postal details etc. Cheers for now.
Oscar WS
Post by Oscar WS » Sun May 07, 2023 9:15 pm
‘Stalk’ now available. I have dropped you a PM.
Oscar WS
Post by Oscar WS » Wed May 10, 2023 1:05 pm
I’ve sent you another PM about your delivery, Gabriel. I did try via the email you gave me but it got bounced back. Best. Oscar
