Behold - the mythical Grille Cover!
(3)433509
I have only ever seen this in the accessories catalogue, never in real life.
https://ebay.us/d90M7N
It even has a peeky-hole so you can still see the badge
Perhaps it's just me that gets excited over a piece of 'official' vac moulded plastic - I need to get out more
Cold Climate Grille Cover!
- 480 Rookie
Re: Cold Climate Grille Cover!
Don't get too excited - it's lost its fixings and had 2 holes drilled in it for cable ties
I just stuffed a 10" x 20" piece of rubber conveyor belt (3/8" thick) in front of radiator, it 'just' fits through the lower gap when curved then drop it around by 90 degrees, blanks bottom section of radiator and is out of sight, it can also get moved to drivers side for hot summer, stood upright.
unless crawling on the deck I think would look nicer than that section of black plastic?
