FOR SALE - trim spares
trim
door trim various + door handles
drivers rh dash trim black jacquard
complete set of door and window trims
complete set of interior trim
external central reflector
complete set of seat belts 1
odd parts of seat belts various
hand brake cover front central console 3
moon roof motor + switch assembly+drain tubes 2
moon roof + motor and switch 2
radiator covers complete 2
radiator fan 2
radiator 1993 non turbo
radiator 1992 turbo
rear central seat belt bracket 2
rear door latches
rear light control socket
rear number plate holder 1
rear seat heater tubes rhs&lhs 1
rear view mirror
rear wiper arm
rhs &lhs side indicators 4
rhs + lhs front lights 2
rhs +lhs quarter light windows 2
rhs side windows 3
lhs side windows 3
rear hatch / window 3
lhs door window 3
rhs door window 3
door - passenger 2
door - driver 2
roof lining (moonroof version) 3
front centre consoles 2
centre console pocket large 3
centre console pocket small 3
centre armrest top 2
dashboard vents
(corner ones) right
(corner ones) left
general vents
rear seat side cubby holes NS 2
front ashtrays complete
steering wheel shrouds upper
steering wheel shrouds lower(with variable resistor)
black plastic bonnet vent grille
narrow aperature cover (below glovebox) (grey)
front footwell vent surround
front footwell vent interior
dash end cover OS black
B pillar external trim
turbo OS pair
plain nS pair
plain OS pair
mixed bag of seat knobs and backrest guides
hand brake cover
air filter boxes 2
sunvisors (pair)
rear clusters internal trim covers 4
upper trim B pillar internal (at seat belt) OS
upper trim B pillar internal (at seat belt) NS
front armrest cubby
coin holder
upper trim rear pillar internal NS
upper trim rear pillar internal oS
rear centre pockets + lids
rear centre pocket lid only
driver footwell lower trim
passenger NS footwell lower trim
tweeter units
connector holders
rear wheel cover trim
seat belt catch
complete moon roof motor +switches+drain tubes and screws
moonroof motor only
moonroof tubing front
moonroof tubing rear
front clusters orange old
rear wiper motor
heater cover and duct assembly
internal rearview mirrors
rear hatch wiring seal
rear wiper washer tubing
front wiper washer tubing
rear hatch hinges
large diameter tubing turbo various
rear number plinth
heater matrix metal support
heater matrix
heater matrix tubing/connecting pipes
petrol cap non locking
tensioning bracket for alternator
rear bracket between seats
various rubber grommets and stops
telescopic bonnet support arms
rear foglight
seat belt support arm
plastic dashboard
complete set of GT leather seats.
jacquard dash trim
jacquard side trim
jacquard door trim
rear seat heater ducts
passenger door
driver door
doorcards
rear side trims
rear side trims with cubbies
rear light assemblies
glove box complete
glove box door
rear seat belt mountings
plus all sorts of bits pieces an stuff.
radiator fan 2
radiator 1992 turbo
rear door latches
rear view mirror
rear wiper arm
rhs side windows 3
lhs side windows 3
lhs door window 3
rhs door window 3
door - passenger 2
door - driver 2
dashboard vents
(corner ones) right
(corner ones) left
general vents
turbo OS pair
plain nS pair
plain OS pair
hand brake cover
air filter boxes 2
sunvisors (pair)
front armrest cubby
coin holder
tweeter units
connector holders
seat belt catch
moonroof motor only
rear wiper motor
rear hatch hinges
rear number plinth
heater matrix
rear foglight
plastic dashboard
jacquard dash trim
jacquard side trim
jacquard door trim
passenger door
driver door
doorcards
rear side trims
glove box complete
glove box door
hey jim,
hope you can help me, i need, 2x backrest adjuster knobs (both mine are shot), rear side trim both sides ( did some cutting for 6x9's, don't like it) switchgear for fogs/ rear heater, spray nozzle for rear screen washer,
if you got all of these, could you price up n tell me how much you would like for said items, i'm new to the 480 so unsure on what to offer, so be kind
cheers, lee
cheers, lee
Where ever I go, There I am.
variuos trim
rear side trim I assume thats the trim with the cubbies in it if so can supply a pair of these , the fogs rear heater switches (the triple switch on the dash ) can also supply, if you mean the little black triangle nozzle should have will check but should have just have find it amongst the rest and also the seat adjuster knobs will check on these have at least one.
will pm later tonight.
regards jim.
regards jim.
Morning Jim,
Having just got the Celeb back from a short spell at the garage it appears that the drivers side pop-up has "lost" one of the retaining lugs (bottom corner) and subsequently 'vibrates' in a slightly non-MOT passing way!!
The lug in question is white plastic, and attaches the bottom of the light unit to the long screw mounted to the backing plate (hopefully that all makes sense - I can't post any pics, as I'm having to email from my work PC for the moment).
Anyway, long story short - would you have a couple spares you could 'sell'??
Many thanks
Roge1
Many thanks
Roge1
kev
if you mean the black slider panel that hides the gap at the handbrake I have a spare as it is integral with the actual handbrake cover. so no problem with that.
The footwell vent do you mean the one in the centre console to the right of the passengers feet (just below the plastice heater ) rectangular and the small material panel has a rectangular 1cm plastic frame attached so you would need the actaul centre vent part ? If so I would need to check to see if I have it.
will pm you later
regards jim.
will pm you later
regards jim.
