Hi, I have for sale a fully working complete drivers side window motor/regulator unit. I removed it from a 1992 es about two weeks ago only to find that mine eventually worked ok (loose connector).If you need it please feel free to make me an offer. I can be contacted on 07856 270203 if i can be of any help,
Thanks Knight
PS- I also have a rear load cover if anyone is interested.
FOR SALE - drivers side window motor/regulator unit
- coyote1980
- Volvo 480 Club Europe CREW
Knight
Think i do need a replacement to my driver's side window. My cable is knackered/snapped and reeled into the motor and window no longer goes up/down and just making a crunching sound. Sorry if i sound thick, but just wonder when you say the window motor/regulator - does that mean the entire mechanism i should replace with and if so how much?
Regards
Rod
Regards
Rod
- guitarcarfanatic
Hi rod,BlueCruiser wrote:Knight
Regards
Rod
the regulator is the whole unit. The cable snaps on them like what has happened on yours due to a crap design. A replacement regulator will solve all your problems and it is just a case of removing the door panel (just a few phillips head screws) and then undoing the six 10mm bolts (4 that hold the regulator to the door and 2 that hold the regulator arm to the glass) and it will come straight out with a little manouvering. A satisfying and very easy fix! Check the allignment of grooves it sits in when you refit the new regulator as If it goes on at a slight angle, it can cause the motor to go again!
Hope this helps,
Rob
Previously...
1989 Black ES - Great runner
Previously...
