Mud flaps
Ben C
Mud flaps
Post by Ben C » Fri Aug 02, 2019 9:29 pm
Does anyone know where I can find the correct mudflaps to fit my 93 ES 2.0? Im looking for original Volvo ones preferably. Are the 440 flaps the same size?
Re: Mud flaps
Post by dcwalker » Sat Aug 03, 2019 12:37 pm
Like most things for the 480 genuine mudflaps are unobtainable unless you happen to chance on someone breaking a car with them fitted. Often removing them causes the metal strips on them (which will already be well rusted) to crumble away as well...
440/460 mudflaps were different - that said, I remember managing to adapt a set to fit a previous 480 I had many years ago. As far as I recall the main thing was having to drill fitting holes in slightly different places.
Good luck!
Re: Mud flaps
Post by Alan 480 » Sat Aug 03, 2019 7:41 pm
Good luck!
I fitted 440/460 to front of 480 and they fitted OK, but an extra hole drilled through bottom edge of inner wing was required.
'Canon' universals on the rears and fitted quite well . . . .
Ben C
Re: Mud flaps
Post by Ben C » Sun Aug 04, 2019 12:19 pm
Good luck!
Thanks David I will soon adapt some I think now that I know there isnt an exact match
Ben C
Re: Mud flaps
Post by Ben C » Sun Aug 04, 2019 12:21 pm
Good luck!
Many thanks Alan handy to know. I will order a set and adapt them
dekkb
Re: Mud flaps
Post by dekkb » Fri Aug 23, 2019 1:44 pm
To be honest, if you need to replace the shocks and springs, don't bother with them. I've just changed mine (exactly the same set up as Jifflemons)They just hit the floor every two minutes anyway. I'll be taking mine off tomorrow as they're just annoying now, I need to hold on to them for now but might be able to let them go over the winter.
Current: 1993 480 ES
2009 Subaru Legacy sportsback (blown engine)
2004 Audi A6 avant 2.4 V6
