Hi folks,
just bought myself a nardi personal from circa 1990, should look good in the car! i've found a boss kit that can be bought online (i need to buy an adaptor to put the nardi onto it but thats no big issue) link below, will this fit?
http://www.ebay.co.uk/itm/MOMO-Steering ... SwDNdVwNzK
can anyone tell me how the standard wheel comes off? i've a 1991 480 with a 2 spoke non airbag wheel!
Aftermarket steering wheel
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
Re: Aftermarket steering wheel
All you have to to take your steering wheel is pop off the horn on the front. It might be a good idea to take the fuse out for the horn if you like peace. Behind the horn is two spade plugs connected to it. Disconnect these and place the horn to one side. You will see the nut that holds the wheel on. I cant remember the size off of the top of my head. 17mm/19mm. Undo this and the steering wheel will pull off.
Concerning the kit it should just go over where you took the wheel off and bolt on. I cant promise though but those kits are pretty universal..
regards
regards
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Cool! Cheers!
Just incase the 480 had different spline patterns in air bag and non air bag models, wouldn't surprise me with a 480 hahaha
