hi there every one. In the hanes manual it says you can only fit thr fly wheel one way but on mine the gap in the teeth for the crank possition sensor is not lined up with the NO. 1 cilinder TDC.is this correct of not?its got a lightened and ballenced bottom end and a high lift cam but it seems to be running even more lumpy than expected.
any help appreciated.
Tom
Flywheel possition
Flywheel possition
if in doubt, get a bigger hammer
- gixfighter
The flywheel can only be positioned in one way, due to bolt array in the flywheel/crank. There are 5 bolts, not equally devided over 360 degrees so there can't be any mistake there. Are you sure you have the right type of flywheel for your computer orange/blue etc ECU?
Renault 19 Convertible with 480Turbo Engine Megasquirted and soon being supercharged
Renault 5 GTE with 480Turbo engine: Rusted
- gixfighter
