T5 engine to 480 Turbo
Hi all!
Is it possible to put a T5 engine under the 480`s hood?
I heard thats too big and it doesn t fit!
Does anyone done this?
madis.maasing@mail.ee
+37253541104
+37253541104
T5 is a good known killer power I don't know about traction on these torques but who knows. Maby a T4 swap would be a bit easier.
1996 850R 2.0 T5 - "Beebi R"
1973 142 GL B20E - sold
- Ettore Bugatti
The T4 engine is a Volvo engine although versions of this engines has been put in to Laguna's (RTI 16V) and Safranes. It is based on the Volvo white block (5 and 6 cylinders found from the 850 and V90).
Besides the size, there's an weight advantage (above the t5 block when considering a swap into a 480). It is probably around 30kg lighter.
But it wont be an easier swap because both (T4 and T5) requires new engine and gearbox mounts, custom drive shafts and reconnected ECU's.
So if want to put labour in it, then better go bananas with it. IMHO
Rover Mini 1000, june 2009-
i was wondering too that T4 is better to fit onJohnTurbo wrote:I'd say if you measured the distance between chassis legs, the T4 would equate to a much easier swap.
T5 is sheaper in our country
i am confused what to do
i quess the only way is modified b18ft+T3
does anyone knows, which gearbox can be fit to take out more torque and hp off b18ft??
+37253541104
+37253541104
- JohnTurbo
A t5 might well shoehorn...it just might require a lot of work.
Bolting a t3 onto a b18ft just seems like an irritating solution, probably more work in the end than grafting in a whole different engine.
- Theres not really enough room, the engine mounts aren't good enough, the gearbox isn't good enough. Theres no easily available, tougher gearboxes to fit.
Just seems like the guys who've tried T3s have struggled.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
but there is a few guys who did that(T3 onto a b18ft) and seems like its easier to fit T5 or T4 engine and other gearboxJohnTurbo wrote:A t5 might well shoehorn...it just might require a lot of work.
so i made my joice:i have a T3 from VW LT and one man who sells me a second engine b18ft to fix it capitally, cos my old engine is dead
Its going to be a hard work to do all the stuff but, who knows...
+37253541104
+37253541104
I can help you with it if you want The engine i have still has its oil in it and the gearbox also. How it runs, I don't know. It's off my parts car. But still you have to make a overhall. Maby you can fit the T3 into a different place with a custom exaust manifold. Maby under the car
- Ettore Bugatti
tubo is a basic airfan powered by exhaust gasses. That is it. Its just one mechanical fan. It doesn't make a difference, where it came from
diesel turbo has more effect at low rpm i quessEttore Bugatti wrote:I never understand why a 120hp diesel turbo would work on a heavily modified B18FT with 200hp.
Isn't there a more modern solution? A GT series turbo?
i just have a turbo from LT diesel engine and want to try how it works with b18ft
someone in this forum told too that volvo 940 2.4 turbo is effective thing on b18ft
volvo 940 turbo is the same as LT s
+37253541104
+37253541104
