rpruen
Post
by rpruen » Mon Jul 17, 2006 7:52 pm
TommiS wrote:rpruen wrote:
The turbos that are known to fit the elbow of the older T2 are Saab 900/9000 T3s and the Volvo 940 Turbo Diesel T3. Both are good to about 2 bar or so.
Richard
So these turbos go to manifold without any work ?
They will fit with very simple machine work. Any local machine shop would be able to do the work. Details of what needs to be done are earlier in the thread. If you are handy with a rotary file, and have a drill press, then you could do the work yourself.
IT shouldn't cost all that much to have someone do the machining work, and if you follow the instructions I have given you still get to be able to bolt on a T2 if you need to in an emergency
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
Little_tortilia_boy
Post
by Little_tortilia_boy » Wed Sep 06, 2006 11:01 am
hy...i still dont know if it is ql to install B18E camshaft and how many rpms more do i get, or is it all nonsense....
Bakke
- Tuning oracle
Post
by Bakke » Wed Sep 06, 2006 11:04 am
the max RPM has nothing to do with the camshaft as the RPM is software limited
Whoever said : " A Volvo cannot be tuned ?!? "
Name: Goldlocks // Type: TURBO // Year: 1988 // Colour: 435 Saffron Pearl // Engine: B18FT (1.7) Rica chip, Custom Volvo widebody and lots of ICE
Little_tortilia_boy
Post
by Little_tortilia_boy » Wed Sep 06, 2006 11:14 am
the engine will be tuned, so also computer...and i need a simple answer....B18E camshaft yes or no...tnx
Little_tortilia_boy
Post
by Little_tortilia_boy » Wed Sep 06, 2006 11:47 pm
nobody?....
sjoerdb
Post
by sjoerdb » Thu Sep 07, 2006 6:00 pm
maybe the B18E camshaft is to heavy for a turbo engine, but maybe a other camshaft is better like the b18EP, if it works you can always try the B18E. i want to try the B18E camshaft in my B18FP engine. hope get a few more HP. but when i know i come here. ciao
480 ES 1991, 102 PK, dyno 97.5 PK. dutch power
haz@nocturnal_development
- 480 Rookie
Post
by haz@nocturnal_development » Mon Sep 11, 2006 8:45 pm
the b18E cam has more lift and duration, fine if you want a higher powerband and runnin alot more boost, i think it works well on mine at 15psi on a large t25, even better at 25psi. probably a bit naff and may cause issues for a t2 runnin at 14psi tho.
haz
reanualt 5 campus, Volvo turbo conversion, hybrid T28, -31 actautor, external oil cooler, THS intercooler, rear radiator, large throttle, Adaptronic ECU, cossie blue injectors. results recorded '06 (21 psi 228bhp/229lbs),(23psi 12.6 @108mph)
Toreto
Post
by Toreto » Sat Dec 27, 2008 4:36 pm
Long time no see
However, I'm having a hard time finding specs for B18XX camshafts. I'll be running a T3/T4 hybrid in a couple of months, so the camshaft is the last thing I haven't decided on, everything else is pretty much figured out. Help anyone ???
Auk
Post
by Auk » Sat Dec 27, 2008 11:09 pm
Are there any performance upgrading camshafts for the B20F?
I'll upgrade this engine too, but couldn't find something on the forum about the 2litre.
Auke
Volvo. for life
esta
Post
by esta » Sun Dec 28, 2008 1:29 pm
Auk wrote:Are there any performance upgrading camshafts for the B20F?
May have the wrong end of the stick, but I have had quotes of £130+VAT for a Kent re-ground cam and I believe it was £230+VAT for a brand spanking new Kent Cam...quotes for my B20f...
HAVE: Jaguar XJ40 4l Sov
www.projectjaguar.co.uk
Auk
Post
by Auk » Mon Dec 29, 2008 9:40 pm
esta wrote:Auk wrote:Are there any performance upgrading camshafts for the B20F?
Yes, I read that, but nobody have done this before isn't it?
Auke
Volvo. for life
esta
Post
by esta » Mon Dec 29, 2008 10:25 pm
Auk wrote:esta wrote:Auk wrote:Are there any performance upgrading camshafts for the B20F?
Ah glad you saw it. One guy on here had a re-ground cam in his 2l, but he hasnt been on here for a while-the guy who did the gold flacked black paintwork (smooth480), and he isnt sure who did it (he bought his ready ground!)
As you are probably aware I may be doing this in the future myself!
renvo1916v
Post
by renvo1916v » Sun Mar 29, 2009 7:22 pm
i got a cam from Quality Engineered Products for 200 quid.even with the timing out and a leaky intake maifold it still feels about 120 bhp altho its not been dyno'd or anything.the problem im having is getting hold of a vernier pully.if anyone knows of one let me know.if not i mite do some drawings and get my frendly local machinist to make me one.if any one is intrested ill post some drawings so you can get them made for your selves.
if in doubt, get a bigger hammer
