Repair mudflaps
Repair mudflaps
I'm sure we've all seen crusty swollen mudflaps with nasty rusted inserts coming through the rubber. Eva was missing both of her offside ones, presumably due to the crash that put her in the scrappie and Lily doesn't have any. Over the years I have been collecting the odd one here and there, and now have enough to have a full set on all 4 cars, including replacing the one I've just been told has gone awol from Snazzy's 'jigsaw puzzle' heap of bits.
So, I had a word with my engineer brother who recommended 0.8mm thick 430 stainless steel to make replacement inserts. A sheet 250 x 250mm is enough to cut a set of four.
First step was for Al to slit the rubber along the edge with a Stanley knife so he could remove all the crud inside. Using the flap as a guide he made a template each for front and back. Once the inserts were in he used Mannol 9912 gasket maker to stick the rubber back together and fill holes where the rust had eaten the rubber away. It remains to be seen how long the gasket maker lasts. Once it was set he drilled fixing holes through the new inserts, then reinforced broken holes in the triangular section with acrylic sheet. My task was to repaint the silver lettering on the rear flaps. The bodyshop said it's the front wheels that throw the stones up so the front flaps are for stones and the rears are for advertising....
Re: Repair mudflaps
Ooooo did Engineer brother happen to make a few sets of inserts?
Re: Repair mudflaps
The inserts are Al's creation, I keep my bro busy with much harder stuff
The stainless came from ebay and wasn't too difficult to cut - he used snips to roughly cut first then tidied them up on the grinder. If they'd needed to be accurate and/or look pretty it would have been outsourced to my go to engineer
Re: Repair mudflaps
Very good! I was toying with the idea of making repro parts as our family business is in rubber components, but it is certainly a relief knowing they can be repaired.
I've go the front flaps but not the rear ones, so will have to find those somewhere!
Re: Repair mudflaps
Thanks for this Sylvia (and Al ).
Looks a very worthwhile exercise...
Re: Repair mudflaps
Tell Al I'm impressed!
Re: Repair mudflaps
Less toying, more doing!
Re: Repair mudflaps
Just added a small refinement to the process - Kurust on all the old rust stains, especially inside the slit. Might just hold back the rust that will eventually get the stainless.
