removing rear lock
malkontent
removing rear lock
Post by malkontent » Sat Jun 16, 2018 8:18 pm
Hi
Removed all electric connections , linkage , lock core / do not forget to insert key ! / and left only yellow metal casing ...and :angry: could anyone help ?
regards
malkontent
Re: removing rear lock
Post by malkontent » Mon Jun 25, 2018 5:35 am
Nobody ?
WRDendy
Post by WRDendy » Mon Jun 25, 2018 7:59 am
I'm afraid I don't know, but it looks like arthuy does. Might be worth a PM?
Formerly known as 'Jaster'
Current: '94 GT & '88 ES
Former: '89 ES
malkontent
Post by malkontent » Tue Jun 26, 2018 7:45 pm
Came to that place :
outside
and inside , what now ?
AleksanderHugo
Post by AleksanderHugo » Wed Jun 27, 2018 12:12 pm
The next step is to remove the metal bracket that holds the microswitch. If I remember correctly then all elements detach.
malkontent
Post by malkontent » Wed Jun 27, 2018 5:33 pm
It is not so easy :D , send a PM to Arthuy , he did this . Look closer to my picture , I removed a small screw at the bottom , but can`t move a yellow casing aside , because of aluminum "pipe" which goes from inside to outside , at the end of that "pipe" is a rubber ring . So I think , the only way is to remove /but how ? / that pipe , outside !
arthuy
Post by arthuy » Sat Jun 30, 2018 12:02 pm
I knew I should have took some more photos.
The yellow metal plate holds the alloy barrel in place. It is just a push fit, you need to lever it off, a long flat screw driver usually works.
Looks like you still have the switch fitted, pull that off too. The lock comes out from the outside.
If you are going to reuse the lock you need to save the little brass spring and ball bearing.
I will try and get some photos next time I am at the spares car.
malkontent
Post by malkontent » Sat Jun 30, 2018 2:55 pm
Thank you very much :D , now it is clear .
arthuy
Post by arthuy » Sat Jun 30, 2018 6:05 pm
Let us know how you get on.
malkontent
Post by malkontent » Tue Jul 03, 2018 7:57 pm
:wall:
arthuy
Post by arthuy » Sat Jul 07, 2018 2:56 pm
Do these help?
Remove the little screw and prise the retaining clip off.
Once this is off the lock will come out, might be stuck with age but will come out.
malkontent
Post by malkontent » Mon Jul 09, 2018 8:21 pm
Hallelujah :D
Did it today , my mistake was , I tried to move yellow casing to the left / looking from inside the car / ,it must go to the right side ! Microswitch holds a alloy barrel , after removing it all is free and barrel goes outside .
