Late mirror cover replacement. 56k go do something else!
Roo
Post by Roo » Sun Aug 13, 2006 9:10 pm
Well, to follow on from my headlining post, I thought a mirror cover replacement how-to might be of some use. Mine were badly damaged and the housings were fairly loose.
So to start:
Pull the mirror glass away from the mirror to release it from its mounting. (its clipped into place) Then remove the two wires for the heated mirror
Then unscrew the mirror motor held in place with three screws (this is not essential but allows better access and I was changing my motor anyway)
In this case, i needed to remove the motor completly so I had to unlip the connector
You can now see the retaining screws for the back trim (the black part) and the clips for the front trim (white part)
Remove the trim by unscrewing the 4 screws. (you may need a short screwdriver for this as the quarter window gets in the way) My mirror trim had two broken tabs.
Release the front trim by un-hooking the plastic tabs. My mirror cover was fecked! New cover shown as a comparison.
When refitting the mirror cover, I lubricated the clips with some silicone spray. This made refitting much easier.
Refitting is reversal of removal blah blah blah....
and the finished article:
Silver480S
Re: Late mirror cover replacement. 56k go do something else!
Post by Silver480S » Wed Nov 05, 2014 8:06 pm
Just a quick question about getting the mirror glass away from the mirror. You said:
I'm having difficulty prising the mirror off. Is there a knack to it without breaking it? I'm close to breaking it I think! :wall:
Thanks for any tips.
My car is a 480S 1.7 1993
timrosser
Post by timrosser » Thu Nov 06, 2014 10:28 am
Thanks for this!
Captain Slow
Post by Captain Slow » Thu Nov 06, 2014 5:14 pm
Silver....I'm not sure theres a knack as it were: you can't get in there to lubricate the clips you can see in the above photos so I think the best you can do is a screwdriver wrapped in a rag and try to release one clip at once?
Previously....
Silver480S
Post by Silver480S » Thu Nov 06, 2014 7:57 pm
Thanks for the tip, Captain, I will give it a go.
Job done! Brilliant!
Post by Alan 480 » Wed Sep 07, 2016 7:16 pm
I need to free off the fold back part and I'm worried that I break the whole thing so I think taking the glass out will allow me access to the spring/pivot to 'lubricate/free
are there four wee clips that hold the mirror glass onto the holder, or is the glass bonded onto a plastic carrier so reasonably 'robust? i've broken a mirror glass on the SS1 trying to prise it off :-(
Post by glasgowjim » Wed Sep 07, 2016 7:42 pm
If memory serves me correctly the mirror glass is bonded onto the plastic backing. Dont worry if it all goes pear shaped I will send you a replacement late mirror glass FOC ;)
Post by Alan 480 » Thu Sep 08, 2016 9:00 pm
Jim
ta for offer, I'll try later on in the week after i fix the handbrake on SS1 which decided to stick ON, :angry: typically the day I needed it as I decided to fit new wishbones to other car and i hadn't finished before got dark :-(
Post by Alan 480 » Wed Oct 05, 2016 6:36 pm
job done, sodding nightmare getting the mirror to turn back and fore, ended up with a junior hacksaw to carefully cut the pivot tube along it's axis to let it drop down slightly in diameter so allowing movement!
