G600DPJ 480 Turbo
royhedger
G600DPJ 480 Turbo
Post by royhedger » Thu Dec 21, 2023 12:06 am
Hello,
Starting a thread about my new toy. It's a very nice 1990 Turbo Auto which I've had for a few weeks now.
I have a list of jobs already and am slowly working through them.
As far as I can see she needs the following.
Engine Undertray
Bonnet sound deadening / insulation - done
Headlight bracket (I stupidly broke one)
Passenger door central locking repairing
Long range driving lamp aim setting
Heated seats fixing
Dashboard dimmer switch replacing
I have already replaced the wiper stalk, pop up light struts, and repaired the tape deck (head needed cleaning and aligning).
She's booked into a Volvo specialist in the new year for a coolant change, and auto box oil change as a precaution.
Looking forward to getting out on some meets next year.
White 1990 480 Turbo Auto
royhedger
Re: G600DPJ 480 Turbo
Post by royhedger » Sat Dec 30, 2023 9:02 pm
Jobs completed this week.
Engine undertray fitted - thanks Ed Waite
Headlight pivot bracket fitted - thanks Dave Walker
Driver's heated seat repair - heater pads from ebay
Dashboard dimmer fitted - thanks Ed Waite
Long range lamps aim adjusted
Post by jifflemon » Sun Dec 31, 2023 11:54 am
Was thinking about this only this morning.... Is it as tedious as I suspect? there's no access to the adjusters once the lamps are in place I presume?
royhedger
Post by royhedger » Mon Jan 01, 2024 8:19 pm
Yes, a bit of a nightmare. Easier to remove, adjust and replace. Then try again 😀
I reckon you could do it in situ if you had small hands..or a special tool.
royhedger
Post by royhedger » Sun Jan 21, 2024 8:45 pm
Just had a full service, including coolant and gearbox oil change at Volmech my local indy in Stockton.
They couldn't find any spark plugs to fit it but I'm not fussed as I have a set at home & they said they didn't need changing anyway as it hasn't done many miles since they were last changed.
Can't wait for the weather to improve and get the salt washed off the roads so I can take her out again. :hopping:
royhedger
Post by royhedger » Tue Jan 23, 2024 7:55 pm
Replaced the headlight dampers yesterday....again.
Initially replaced the old ones with ones I got from SGS Engineering, but the headlights seemed to struggle, and had a little extra push when they were 3/4 up, so we're not very smooth at all.
I decided to bite the bullet and order some from Volvo fan in Poland.
They arrived after about 2 weeks, and I must say they are so much better than the sgs ones, definitely worth waiting for.
Headlights operate up and down better and are silky smooth.
mandi
Post by mandi » Wed Jan 24, 2024 5:59 am
could you please share the contact in poland ? ;) ;)
thanks mandi
Post by jifflemon » Wed Jan 24, 2024 9:56 am
thanks mandi
https://www.ebay.co.uk/str/volvofanpartsstorepoland
Or if you're in Poland:
https://www.ebay.pl/str/volvofanpartsstorepoland
Post by Jay-Kay-Em » Wed Jan 24, 2024 9:58 pm
Hi Roy,
Looking good.
Can I just ask - has it had that plate from new?
Also, eBay is full of NGK ZGR5B so your specialist didn't look too hard. Even with specialists, you have to invest the ground work yourself because it isn't worth their time to search.... and you can understand that to a certain extent.
royhedger
Post by royhedger » Thu Jan 25, 2024 10:44 am
I've no idea whether it's had the same plate from new unfortunately Jay. I have only had the car a few months.
I think so, but couldn't confirm.
Unfortunately unless they're in stock at Volvo or Euro car parts they don't look much further. I have a set of plugs in stock, so not really bothered about it.
I bought the dampers from here https://www.volvofan.eu/Gas-spring-Pop- ... p2036.html
royhedger
Post by royhedger » Thu Jan 25, 2024 9:36 pm
I was interviewed and had some photos taken today by Practical Classics. Hopefully will be in the mag in the next few months.
Post by MisterH » Sat Jan 27, 2024 12:44 pm
Ooh looking forward to that, what was the theme? Must say that is eclectic!
royhedger
Post by royhedger » Sat Jan 27, 2024 9:41 pm
There wasn't really a theme. He wanted to take a shot of all the cars together, but also took loads of the cars on their own with their owners.
He said it would be a car of the month sort of thing. A bit impromptu really, they put a message on Facebook and asked for people in Teesside to show what interesting cars they may be interested in for a slot in an upcoming mag, as they were in the area interviewing someone. I posted a pic of mine and I got an email asking me to attend the photo shoot if I could spare the time.
royhedger
Post by royhedger » Fri May 03, 2024 7:29 pm
Done quite a bit to her since my last post:
Cam belt and water pump changed
Fuel pump and filter changed
Brake fluid changed
Lots of rattles sorted (still some to find though)
Stripped rear bumper off and sorted the inner crash bar.
New passenger central locking motor
New DAB radio/MP3 player with hands free phone connectivity
Lanoguarded / hammerited / rust protected wheel arches, inside doors and underside where needed
There's a few things still to do:
Slight Brake squeak on hard braking
A few vibrations /rattles to find/ fix
Light switch lighting to fix
Small oil leak poss sump seal
Replace throttle cable with good used one (adjuster broken)
Passenger heated seat fix
Passenger door bump trim scrape to polish out
Align bumpers properly
Replace orange stickers to open sunroof sides
I do love tinkering with her 😀
