Ok so I used Romsey Car Accident Repair, Jon who runs it is very good at what he does and will be realistic with it.WillC9303 wrote: ↑Sat Feb 05, 2022 9:31 pmThanks for the reply, I'm hoping that the info centre just 'fixes itself' at this point. It's not inherently broken, its just giving wildly inaccurate readings so I'm not too worried at this stage now. I might bring it inside to dry out and hope that fixes it. It sounds like your car was possessed! I can thankfully say while mine isn't possessed per se, I would describe it as 'throwing a tantrum' If it does get worse though, I won't hesitate to describe it as suchMisterH wrote: ↑Sat Feb 05, 2022 7:14 pmSo sorry to hear this Will, but I know you are in absolutely the right place to get it going again.
Now the things that I can comment on.
Info Centre: you may already have tried this, but Take the dash out and have a good look behind it, check the circuit board is in good shape, if it is, then take a look at the big block connectors that plug in. Get some Contact cleaner and WD40, and squirt it into the connectors to get the connections working well. While you're at it have a go at getting any other electrical contacts as it can't hurt (usually) and it'll possibly sort a few other problems you didn't know you had. If all else fails, give it a Dutch Holiday (no not that type) and see if Brinkie can make head or tail of it (he will probably make both) and that should be the dash sorted.
Bodyshop: Well I know you live Woking way, but if you are really determined I know one near me who are very good, and will (hopefully) be doing mine (again) soon, although it will probably be unfeasible given that it will be hard for them to come out and give it a quote. Although if it isn't hindering the cars driveability, then once it is ready for such a trip feel free to drive down to mine and we can go see them, it'll be a good shakedown for it and could give you some more clues as to any issues.
These cars do have a tendency to throw curveballs, mine was practically perfect in every way, then one summer evening it was possessed by an evil spirit, or so I thought. The wipers were going haywire, and would only stop with the passenger door open. Only that this stopped the indicators. I opened up CEM and found that a tiny bit of residue had breached one of the circuits on the motherboard. Plugged a new one in, totally fine. You will get there, you are not alone
As for the body shop - do tell - The one's I've tried contacting in and around Woking clearly don't want my business, so I may as well go elsewhere.
https://romseyaccidentrepair.co.uk/
It is a bit out of your way, but they are very professional and we have used them several times, and well, the results can be seen on my (pre Bin lorry) 480
