Post
by Alan 480 » Mon Apr 12, 2021 6:01 pm
jifflemon wrote: ↑Sun Apr 11, 2021 7:31 pm
Oh come on, they’re
obviously NLA!
Coil overs are available (very expensive), my worry would be that the bearing would be on the strut top, not the spring pan.
ah, suspicions confirmed
I knew coil over were 'nae cheap', but as long as thrust bearing DOES exist then all is OK? were there bearings on the Mk2 Cortina version?
I considered 'alternative' struts but you'd need a friendly motor factors to compare them with, ie set a Volvo one and find a version that has similar distance from hub to clear the disc etc and similar mounting at bottom end, surely lots of other cars of similar vintage used a 'two bolt clamp'?
in the mean time I'm washing mine with garden plant watering attachment each time car is washed
phil480
Post
by phil480 » Tue Apr 20, 2021 12:30 pm
Great news, I am happy to report that my 480 passed MOT this morning with just one advisory "corrosion under side vehicle in places". We'll have that sorted soon, hopefully along with the high idle speed. I was certain that it would fail on the emissions or the idle speed being too high, especially as it was at a Halfords auto centre which I know don't have a great reputation with most, but our local one has been very good with our other car over the last few years so thought I'd give them a go.
I am relieved that all our hard work has paid off and it's back on the road (just in time for the tax renewal, £270 oof!). Even the MOT tester complimented me on the work we had done and said he hopes to see it next year for another pass.
So, total spent so far is about £550 including delivery of some parts from Europe.
Next up, service and cambelt change.
Current: 480 GT 2.0 '94 in Red
Previous: 480 ES 2.0 '93 in White K464SWP -Sold in 2009. Presumed dead
Post
by jifflemon » Tue Apr 20, 2021 1:16 pm
Excellent news! You know all the parts you need for that?
Alternator belt: 3PK595
Main Drive Belt: 6PK1555
Timing belt: K015370XS
Oil filter - Volvo (shock! A 480 part available from volvo!)
Air filter - Anywhere!
Fuel filter - Please change it.... Bosch 0 450 905087
Plugs - NGK BPR7ES
Cap - Lucas DDB248
Rotor - DRB243C
Water pump (if you're doing it) - Get a Valeo one, nothing else!
phil480
Post
by phil480 » Tue Apr 20, 2021 1:38 pm
jifflemon wrote: ↑Tue Apr 20, 2021 1:16 pm
Plugs - NGK BPR7ES
Cap - Lucas DDB248
Rotor - DRB243C
Thanks for those part numbers Jeff, very useful! Cap and rotor have been done already
