1987 480 ES Project -- D-reg, 2nd oldest in UK
Re: 1987 480 ES Project -- D-reg, 2nd oldest in UK
If you find yourself over MK way, I can send you packing with plenty of chemicals to assist!
Thanks Jeff! Would love some but not quite sure when I'll be that way. Would be tempting to pop by if I get the car MOT'd before the mini meet.
Basically I'm back on the 7th and we all meet on the 12th.
In that case i’ll Bring some on the meet; we can either do it during a pitstop or you can take home with you
- WRDendy
If you're thinking about running an engine-cleaning seminar then sign me up as well!
Formerly known as 'Jaster'
Current: '94 GT & '88 ES
Former: '89 ES
Former: '89 ES
We'd be interested in a cleaning demo as well. How about 12th May ?
There has been a huge amount of work done since the last update.
I have to confess that *my* work stopped once I finally got it to start and drive once again as I've left the country for my job and wont be back until May 7th. The baton has been taken by the tame village mechanic who is my friend and he has really ran with it!
When the MOT was done on the E-reg car I showed them a picture of this car's windscreen and they've said that there is a good chance of it passing as the rules have just been significantly relaxed-- basically is it in my field of vision, yes/no. So, the plan is to get everything done except the window and see if I can get to the May meet with it. I am absolutely itching to get back and see it and most importantly to drive it!
I had had:
Fingers crossed this one and Keith's earlier one will be joining you on May 12th.
We are waiting on parts deliveries on
I'd like to get the radio working before a long drive too, even if it gets a temporary aftermarket one which I have sitting in the garage. I've also got some ancient Kenwood tweeter/mid/crossovers in the garage which I never got round to fitting to the other car. Unlike all other UK cars, this early car (along with Keith's) must have had no speakers as standard-- currently some crap looking 90's Sharp items and still no tweeters which make such a difference to the sound.
Before I come home, I might be meeting Brinkie in Amsterdam and we at get a few parts from Orlando's 480 heaven for the interior and the aux. water pump bracket
Have also requested rear light seals and DRL lenses (melted(!) on this one from corrosion on terminals generating heat, rather than gone dull!) from Joep.
If not, a little trip to Lake's should hopefully yield a couple of bits. I'm going to call tomorrow to request that they don't squash the last 480 in there!
And dare I say it....... an MOT?
I had had:
- four tyres (Avon ZT-5)
- timing belt and tensioners
- water pump
- radiator
- repair to lower hose using piece of new upper hose
- coolant change
- gearbox oil change (I went with Brinkie's Elf stuff for now)
- service completed (fuel filter now done too)
- hand brake cables
- brake pipes (not all, but certainly the rear) and hoses (all)
- brake discs/pads (bought the Ultimax package from EBC... will report back as to whether or not they're any good)
- rear wheel bearings
- door hinge and check strap welded up
- number plates
- heater temperature slider
- refurbished callipers (BCS Automotive: stripped, replaced seals, painted)
- gas struts (SGS Engineering: boot ones replaced, wouldn't re-gas; pop-ups re-gassed)
- headlight washer three-way valve and joiner tube (universal stuff to replace damaged valve and cut pipe)
Last edited by jamescarruthers on Tue Apr 24, 2018 10:52 pm, edited 9 times in total.
We saw this on Monday when we dropped a door card off for it - looks SO different to the ebay pics. Lots of hard work obviously been done, spotless under the bonnet - great save !
Oh, yeah forgot to mention that! Thanks again to you two and was pleased you got to see it; sorry I missed you but really appreciate the effort to come and drop it off.dragonflyjewels wrote: ↑Tue Apr 24, 2018 7:44 pmWe saw this on Monday when we dropped a door card off for it - looks SO different to the ebay pics. Lots of hard work obviously been done, spotless under the bonnet - great save !
Although the door is welded up, the inner handle snapped from the previous owner wrestling with it to shut the floppy door.
great effort.jamescarruthers wrote: ↑Tue Apr 24, 2018 7:55 pmOh, yeah forgot to mention that! Thanks again to you two and was pleased you got to see it; sorry I missed you but really appreciate the effort to come and drop it off.dragonflyjewels wrote: ↑Tue Apr 24, 2018 7:44 pmWe saw this on Monday when we dropped a door card off for it - looks SO different to the ebay pics. Lots of hard work obviously been done, spotless under the bonnet - great save !
the inner handle WILL be an MoT fail, you have to be able to open the door from inside, opening the window doesn't count
Got off long flight home and no sleep but did take it for an MOT yesterday lunchtime.
Failed:
Not enough reserve travel on handbrake (fixed)
Headlight adjustment (I will unseize today and replace the screw head cups as necessary)
Windscreen cracked (so much for the relaxed new regulations!)
I'd been awake for two days at this point so my mate took the window out last night and today we're going to tackle the rust. New screen booked for Friday.
Only unpleasant surprise is that I found the front L/H engine mount is broken. Didn't really show itself until driving. I'm attempting to get a replacement but it is still driveable should this be the only thing stopping me coming on the 12th.
It drives very nicely apart from that. Engine is lovely and smooth and pulls well.
Failed:
Shame. Car looking very nice though.jamescarruthers wrote: ↑Wed May 09, 2018 8:05 amWindscreen cracked (so much for the relaxed new regulations!)
As you have taken the old screen out did you get a discount?jamescarruthers wrote: ↑Wed May 09, 2018 8:05 amI'd been awake for two days at this point so my mate took the window out last night and today we're going to tackle the rust. New screen booked for Friday.
If so and if you don’t mind me asking what will you be charged? Would like to know for when the time comes.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
I have a spare inner door handle, driver side I think
Plan A went wrong as the guy who was coming Friday couldn't get a screen. Plan B was a 7hr round trip to Durham to collect a screen (£150) and have it fitted by same guy (don't know price). Window was from here: http://windscreens4sale.co.uk/product/v ... brand-new/eye of ra wrote: ↑Wed May 09, 2018 12:33 pmShame. Car looking very nice though.jamescarruthers wrote: ↑Wed May 09, 2018 8:05 amWindscreen cracked (so much for the relaxed new regulations!)
Plan C: More ringing round found another company for more money. Window is £225+VAT fitted. I am going to double check today to see if they really did get the screen.
Good idea about asking for discount. He wants cash anyway so I'll see what he says when presented with a nicely painted frame that he doesn't have to do any work to or remove the old screen.
In the past when this wasn't so urgent, the cheapest quote I got was £180. It was either with National or Autoglass. Either way that wasn't going to work as National can't come for weeks and now said they can't get a screen and Autoglass "temporarily" are only doing insurance work.
I'm off for a screenless MOT today with my goggles on! Should be fun!
If it all goes wrong, I have to go back to plan B and get myself to Durham. Really not looking forward to that if it does happen.
I love Classic Car insurance. Added this car to current car's policy with Footman James for £32!
I did find them when looking up prices.jamescarruthers wrote: ↑Thu May 10, 2018 6:57 amWindow was from here: http://windscreens4sale.co.uk/product/v ... brand-new/
When I looked Autoglass quoted me over £300. Didn’t really look any further as it’s going to be a while before I need it I just wanted an idea.jamescarruthers wrote: ↑Thu May 10, 2018 6:57 amIn the past when this wasn't so urgent, the cheapest quote I got was £180. It was either with National or Autoglass.
+VAT... but wants cash!!!jamescarruthers wrote: ↑Thu May 10, 2018 6:57 amWindow is £225+VAT fitted...... He wants cash anyway......
Will be very interesting if that works.jamescarruthers wrote: ↑Thu May 10, 2018 6:57 amI'm off for a screenless MOT today with my goggles on! Should be fun!
I’ve never understood normal multi-car insurance advertising a 10% discount for second car. You can’t drive two cars at once so it should be 90% discount on the lowest risk car just in case it’s stolen or spontaneously combusts on the driveway.jamescarruthers wrote: ↑Thu May 10, 2018 6:57 amI love Classic Car insurance. Added this car to current car's policy with Footman James for £32!
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
MOT is passed. Need to brush my hair though! Advisories: minor leak on exhaust and "no front screen fitted at time of re-test".
Waiting for screen tomorrow and gearbox mount today!
So still too early to ask which car you will be in on Saturday!
Windscreen is installed and I'm good to go! The price wasn't great at £258 (£215+VAT). For future reference, you could save money by buying the £150 one from up north and then paying for install only which I got quoted for £50 to only fit. A little bit more, but all I could arrange for our 12 May deadline.
Even had time to do some little jobs like change the DRL lenses, fix the radio and install a roller blind boot cover which I've had in the cupboard for 5 years. Had a go at dying Skip's old green mats grey but it looks pretty crap!
So.... I'm coming tomorrow and am absolutely delighted!
Unfortunately, due to one of the UK's many useless courier companies a next-day delivery of the engine mount is now on day two. It is "out for delivery" so fingers crossed it will come in time. Either way, I think the car will be okay, just no hard acceleration. If I'd have known that UK Mail were so useless I'd have driven to London to collect the part.
On my way to get the tracking done, I've just driven past a beautiful light blue G-reg turbo parked up. Can't believe it! Will get a photo on the way back if it's still there. What a great coincidence!
