Page 11 of 11
Re: The Wolf roams
Posted: Tue Mar 29, 2022 11:07 am
by WhiteWolf
Greetings all....
Can anybody please link the 'how to' on getting the vem out as I've forgotten where it is, I've just stripped my dash and I thought it would be just two screws then it would pull out, no chance..
I've also ordered some headlight bulbs as my passenger side one is very dim, it doesn't do anything not even high beam, hopefully it's just the bulb as I swapped the relay over and it's still the same..
Many regards....
Re: The Wolf roams
Posted: Tue Mar 29, 2022 2:55 pm
The vacuum block at the rear needs to come off as well as the slider wire - Watch for the clip that WILL want to ping off and vanish down the back of the dashboard. I then undo the lower frame attachment points before wiggling it all out.
Re: The Wolf roams
Posted: Tue Mar 29, 2022 6:44 pm
by WhiteWolf
Thankyou for the reply, I will have a look as I didn't see any more screws to undo, does it prise off or are there screws... I stupidly undid the screws from the mounting frame and managed to wriggle the vem half out the frame..
Regards
Re: The Wolf roams
Posted: Wed Mar 30, 2022 10:59 am
by WhiteWolf
Soooo, I decided to have another go at removing the vem today, stripped all the dash and got as far as removing the clip and wire on top of the unit and managed to wriggle it out, I could see two plugs then about 5 wires in a plastic sleeve also connected to the unit, I couldn't see how to remove the big wires so decided to put it back together, then disaster, I couldn't get the wire back in that adjusts the temperature and I also snapped the clip.. I routed the wire to near the steering column so it's like the old style choke, I just pull it in and out
The vem is working 99% of the time, is there anyway to bypass the heater altogether as I don't need the Aircon...
Still awaiting the headlight bulbs, I just hope I don't snap the pop up lid as it sounds fun changing the bulb
Regards
Re: The Wolf roams
Posted: Fri Apr 01, 2022 3:15 pm
by WhiteWolf
Today was the day I decided to change the bulbs that I hoped had blown, passenger side headlight and drivers side DRL...
Taking off the drivers side cluster was easy enough, one of the filaments had blown so I replaced the bulb but banged it when I was placing it back in blowing the filament
I had ordered two so I grabbed the other one and placed it in carefully and replaced the cluster, its brighter when the popups are down and dims when the main headlight is on, success, sadly I noticed the passenger side one needs replacing as that is just dim..
I then moved onto the headlight with a slight worry it wasn't the bulb, I stripped the popup down and pulled the bulb and it hadn't blown, what I did notice though on one of the bulb contacts is that it was rusted, I placed the new bulb in and nothing happened, gutted.. I decided to clean the plug and thankfully the bulb came on bright.. I can now drive my car at night or in the rain
The heating works if I push the VEM but that's another battle altogether, I know it isn't ideal and hopefully in the future I can take it somewhere to someone who knows what they are doing and replace it altogether, I would pay over the odds to have it fixed...
Regards
Re: The Wolf roams
Posted: Fri Apr 01, 2022 3:18 pm
by WhiteWolf
Re: The Wolf roams
Posted: Fri Apr 01, 2022 3:23 pm
Thatβs a symptom that some contacts have died in the flasher stalk. Iβve only ever fixed this by replacing itβ one attempt at opening it up was a disaster!
Re: The Wolf roams
Posted: Fri Apr 01, 2022 3:40 pm
by WhiteWolf
jamescarruthers wrote: βFri Apr 01, 2022 3:23 pm
Ahh thanks for the tip, I think I have a spare one somewhere so I will give it a go
