RADweld advice
chigo
RADweld advice
Post by chigo » Sat Apr 15, 2006 9:57 am
:badmood:
Not sure if this is the right forum to post this --- i just want to know if any of you have experienced any engine problems using the HOLTS RADweld solution to patch up a leaking rad.
Is this product save to use on my rad ? My rad has sprung a leak due to age (i'm assuming)
Red 1990 Volvo 480ES
[img]http://www.geocities.com/dtabo75/avatars/go480_ani.gif[/img]
robin_xr4i
480 Expert
Post by robin_xr4i » Sat Apr 15, 2006 10:07 am
My first metro had a leaking radiator used radweld and it sorted it out for a bit its a quick fix not a solution.
Solution = buy a new radiator :D
[img]http://i15.photobucket.com/albums/a376/robin_xr4i/newsign.jpg[/img]
My old Volvo 480 // Type: Turbo // Year: 1992 // Colour: 305 - Black Metallic // Engine: B18FT // Mods: Rich Mod, Recirculating Piston Dump Valve, Pi Lowering Springs, Induction Kit
JohnTurbo
Post by JohnTurbo » Sat Apr 15, 2006 10:18 am
I poured two bottles into my Xantia to cure a leaking heater matrix. - To get at that you need to basically strip the whole front of the car. Its been in for a few months now with no problems.
Seem to remember reading that theres better ones out there...that was on frenchcars.co.uk forum though i think.
Again, its a fix more than a solution...i don't much care about the xantia long term.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
MGB_GT
480 Expert
Post by MGB_GT » Sat Apr 15, 2006 12:59 pm
Having a problem with a leek in the coolant system myself at the moment on the es. My Garage told me NOT to use RadWeld, something about the design of the Renault Engines particulary disagrees with it apparently, far too technical for me to understand, however he generally knows his stuff. Surley a new Radiator (or second hand one) shouldn't be too expensive and your going to need it in the long term anyhow.
Penelope - 97P Rover 618 Silver
The departed:
480GT - 94L Dark Green Met
480ES (2.0) - 93L Vase Green Met,
480ES (1.7) - 89G Black
480ES (1.7) - 88F Gunmetal Grey
martinholmesuk
Post by martinholmesuk » Sat Apr 15, 2006 4:54 pm
I'd go new rad mate! I heard someone used pepper :? to seal a leak.
Audi TT
chigo
Post by chigo » Sat Apr 15, 2006 6:14 pm
Thanks guys for your opinion --- i asked my uncle this afternoon and he too was concerned that this radweld product could end up sending some small metal particles into the engine --- that alone was enough to keep me at bay with throwing that stuff in --- MGB_GT however has made me fear throwing in that stuff.
I knew it as being a temporary fix and in fact i have my eyes on a few suppliers of new rads. monday i'm off to checkout this second hand one and if my mechanic gives it the thumbs up, i think i go for it. A new one here costs around £230 so i'll prob either buy this second hand one or just buy one off ebay.
Below are some pictures of the 2nd hand rad...
SteveR
Post by SteveR » Sat Apr 15, 2006 10:56 pm
If your second hand one does not cost much it may be worth a go. It looks as though there has been some leaks - the white stuff, but probably external - from the rubber pipes. Look very carefully at the bottom corners of the rad for signs of leaks.
I ended up buying a new one, having paid £25 for a 2nd hand, but in uk it was £75.
SteveR
Steve Robson
This was my K Reg 2L LtdEdn TwoTone - now sold
At Nurburgring (pic Suddy)
No longer a 480 owner :-(
chigo
Post by chigo » Mon Apr 17, 2006 1:09 pm
Thanks SteveR --- i'll take yr advice and let you guys how things go.. :)
MGB_GT
480 Expert
Post by MGB_GT » Mon Apr 17, 2006 11:07 pm
chigo wrote:Thanks guys for your opinion --- i asked my uncle this afternoon and he too was concerned that this radweld product could end up sending some small metal particles into the engine --- that alone was enough to keep me at bay with throwing that stuff in --- MGB_GT however has made me fear throwing in that stuff.
Whoa, not looking to give anyone the Heebe Jeebies, my mechanical knowledge is basic!
It was something about Renault Engines having holes in the engine which seem to attract particles as Radweld goes through the system, these don't come back out again or something, I forget exactly what part or techincal terms, but I've gotta see my Mechanic tomorrow I'll write it down and post it, may be of use to people on here.
The departed:
volviz
Post by volviz » Tue Apr 18, 2006 9:00 am
Have herad something too.... that stuff my block water chanells and you can end by cooking your engine... so be aware!!!
Image&ImageImage
MGB_GT
480 Expert
Post by MGB_GT » Tue Apr 18, 2006 5:41 pm
OK, the Renault Engines have a small breather valve in them, RadWeld can clog it up which can then cause the engine to overheat.
The departed:
chigo
Post by chigo » Wed Apr 19, 2006 6:40 am
Picked up 2nd hand rad and my mechanic advised against installing so -- os off it goes back to the yard. (thank god i know the people and they have accepted to take it back)(that is how things are done in Malta ;) )
Anywayz i am arranging to get a new rad as the 2nd hand one had a massive hit on the mesh and part of the mesh was disintegrating .... so not worth the time changing to such an old one.
Thanks for the advice guys ---
chigo
Post by chigo » Thu May 04, 2006 9:38 am
Well guys --- my 480 is 100% now.
- Cooling is 100% --> new Nissens rad and a couple of new hoses :D
- Idling is 100% perfect --> changed the throttle body. now water inlet is being used :D
Didn't use the radweld after all, and i gave back the 2nd hand rad on yr advice and my mechanics.
i average about 10.2lt per 100Km now which is the equivalent of around Lm5.00 --- i think that would translate to around 28-30mpg.
Thank you all for your advice!
:hopping:
Williewammes
Post by Williewammes » Thu May 04, 2006 1:37 pm
Great job replacing aint it? Did it last week, cost me about 8 hours of work. (3 hours dismanteling it from an old turbocar).
Experienced by the way that you can use both the old as well as the new type radiator. The differnece is in the ventilation, but that's solvable.
Good to see the problems solved.
Greets,
Williewammes
Volvo 480 turbo Paris bleu metallic 1992.
Volvo 480 turbo Grey metallic 1987
Check: www.wdesignonline.tk
chigo
Post by chigo » Thu May 04, 2006 2:07 pm
In fact my mechanic DID say that it gave him a mega hassle to figure out how to remove the nose cone. he resorted to his pal (the panel beater next door) and in the end according to him he still didn't manage altogether --- in anycase at the end of the day he managed to fit and hook it up -> so I'm a happy man. :o
I am looking for a that piece of piping that goes from the air filter to the throttle body as mine has some cracks in it. To identify it, it has a piece of metal wire around its grooves. If anybody has a spare one he feels like sending over, please PM me !
D.
Williewammes wrote:Great job replacing aint it? Did it last week, cost me about 8 hours of work. (3 hours dismanteling it from an old turbocar).
Williewammes
Post by Williewammes » Thu May 04, 2006 2:17 pm
Well,
I didn't encounter that many problems removing the nose cone. But it's kinda not logical how it goes. You have to remove the light clusters before removing the cone.
Removing the bumper, wich apairantly had some damages left from the previous owner, was more of a hassle.
When you more often encounter problems, try downloading the partbook and some other documentary. I found it very usefull during repairing. Till now, I never needed a Haynes manual or something, just the partbook is good enough. They are in the download section of the 480 europe website.
Good luck with it
Greets,
Williewammes
chigo
Post by chigo » Thu Jul 06, 2006 7:52 am
:angry: sprung a leak in my water pump ... :?
Tomorrow it gets replaced... :wink:
