Can anyone look up for me the method of entering the code on a VC802 radio please?
Thanks, Chris.
Radio code
- chriskay
Radio code
2 Kings; Chapter 9 Verse 20
- Captain Slow
Re: Radio code
Turn it on. Display will say ''code''. Hold down the '1' on the pre-sets until it bleeps and one digit flashes. Enter the first digit of your code by scrolling through the numbers using the right&left arrows, when you have the correct number press '1' and you move onto the second digit. enter 3rd&4th in same manner, after 4th hold down '1' and you should have your radio once more!
Previously....
Re: Radio code
Captain Slow wrote:Turn it on. Display will say ''code''. Hold down the '1' on the pre-sets until it bleeps and one digit flashes. Enter the first digit of your code by scrolling through the numbers using the right&left arrows, when you have the correct number press '1' and you move onto the second digit. enter 3rd&4th in same manner, after 4th hold down '1' and you should have your radio once more!
Hello Captain,
do you also know if a SR701 can be decoded in this way ?
Thanks!
- Captain Slow
Re: Radio code
I've no idea!
If there's a similar set up of buttons then its worth a try I would say.
Previously....
Re: Radio code
Hi
I need some help in re-coding my original Volvo 480 radio. I have the code but can't for the life of me work out how to enter the numbers. I have used the preset numbers 1-4 but the code has numbers above 4. Also, when you have entered the code, how do you finalise the operation or does it do it automatically?
Thanks for the help, radio works again hooray.
480 GT Green Aug 1994 "Sven"
480 Turbo Robou Paris Blue Aug 1992 "Eva"
SAAB 9-5 HOT Aero estate 2008 Black "Kemosaaby".........weasel xxxx comes to mind.
Previous cars.
940 2.3 SE Turbo May 1995 Burgundy "The Spy"
850 SE 2.5 1996 Burgundy. "Mew"
940 2.0 White "Dexy"
Previous cars.
