Does anyone have some pop up headlight hinges?
GCooper
Post by GCooper » Wed Jul 14, 2021 2:56 pm
It would cost 60 euros with shipping to the UK so I was wondering if anyone here had some they're willing to sell?
Pictures attached
http://imgur.com/a/hoQRyL3
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
Re: Does anyone have some pop up headlight hinges?
Post by jifflemon » Wed Jul 14, 2021 3:34 pm
Good to see you again! Hows the GT?
Do you know anyone with a 3D printer? If so you can print your own
GCooper
Post by GCooper » Wed Jul 14, 2021 3:47 pm
how's the GT
Well, it still drives
Airbag light, both window regulators need replacing, windscreen washer pump and some other stuff.
Should be mostly sorted soon
'98 BMW Z3 (daily)
Post by jifflemon » Wed Jul 14, 2021 3:51 pm
Have the regulators snapped? Again you can 3D print a repair kit
If the motors aren't spinning at all, check connections at multi plugs aren't corroded.
Washer pump - For the purpose of MOT, you could swap the front and rear pumps over (rear pump isn't MOT testable).
New pumps aren't expensive though
GCooper
Post by GCooper » Wed Jul 14, 2021 3:55 pm
The right window is completely detached from the regulator and the left gets jammed, I think it's because of a loose cable
'98 BMW Z3 (daily)
Post by MisterH » Wed Jul 14, 2021 6:07 pm
That happened to me once (my fault)
But I was able to fix it by threading the metal wire back round the sprocket, but my fingers did not forgive me for a long time!
Post by brinkie » Wed Jul 14, 2021 7:43 pm
Send me your address, a very kind 480 driver who's moving house and needed to get rid of stuff has given me a four of these headlight hinges to share amongst the needy!
Postage won't be Skandix-priced: 6 Euro.
GCooper
Post by GCooper » Thu Jul 15, 2021 6:53 am
I'll see if I can fix it myself, if not I'll get a new regulator. I haven't looked at the driver side yet, it wasn't a priority because I managed to close it by hand
'98 BMW Z3 (daily)
Post by Alan 480 » Thu Jul 15, 2021 8:17 pm
Airbag light,
remove bulb, sorted :-)
GCooper
Post by GCooper » Thu Jul 15, 2021 11:00 pm
If I can't fix it before the MOT this is what I'll do
'98 BMW Z3 (daily)
GCooper
Post by GCooper » Wed Sep 15, 2021 7:42 pm
Airbag light,
This is what I'm going to do, I've also ordered a 1989 steering wheel with no airbag
'98 BMW Z3 (daily)
Post by jifflemon » Wed Sep 15, 2021 8:03 pm
You realise you’ll need a few more bits?
Upper column and light stalks are needed too
See Jay K’s post
