Under Bonnet Deadening/Insulation
Re: Under Bonnet Deadening/Insulation
Post by jifflemon » Wed Mar 20, 2019 7:27 pm
Wed Mar 20, 2019 6:47 pm
shame on you for not having a piece of padding under bottom edge, :wink:
That's the joys of
a) Having a car with more damaged panels than good ones.
b) Spares!
:rofl:
richard-smyth
Post by richard-smyth » Fri Jan 28, 2022 12:02 pm
Thanks for this post. Have just ordered up the 20mm bonnet insulation with foil covering.
My 2 litre 480 only has a cut out in the middle of the middle section of the old insulation.
Would like to ask, do diffident engine sizes 1.7, 1.7 Turbo or 2 litre have different insulation cut outs ?
Think my old insulation cut out is for the 2 litre fuel injection mechanism.
Will report back how it goes and with some pictures.
Cheers, Richard.
Post by jamescarruthers » Fri Jan 28, 2022 1:41 pm
I think you are right, there have been different cut outs over the years.
richard-smyth
Post by richard-smyth » Fri Jan 28, 2022 2:17 pm
You're on to your 8th 480 ?
I haven't even seen that many 480's in whole of my life so far and I have driven about 30k a year for the last 28 years for work.
Cheers, Richard.
Post by jifflemon » Fri Jan 28, 2022 4:05 pm
Puds bonnet was had the correct insulation bonnet layout. Just mimic that and you should be fine.
I do think they were different between models - If I remember I'll grab some photos of the ones I've got.
Post by dcwalker » Fri Jan 28, 2022 5:44 pm
Cheers, Richard.
Then you definitely need to come along to the next meet! :lol:
As Jeff says, just use the existing foam on Pud as a template.
