Cracked Washer Bottle
ohdearme
Post by ohdearme » Mon Jan 16, 2017 10:57 am
My ES Auto has a crack around the top edge/corner of the washer bottle, meaning that when I go over a bump water splashes out.
Has anyone tried to repair the plastic bottle?
If I wanted to replace it are there any hidden challenges.
Trevor
Red 480 ES Auto 1991
Bought 2016, hoping to use a weekend car in 2017
First classic car, learning a lot, but having fun
Re: Cracked Washer Bottle
Post by Alan 480 » Mon Jan 16, 2017 12:46 pm
if not concerned with 'originality' silicone sealant (clear) would be my first thought.
the bottle does come out but a bit of a PITA to be honest as other hoses get in the way!
ohdearme
Post by ohdearme » Mon Jan 16, 2017 7:42 pm
Thanks for the warning about trying to remove it.
Sounds like silicon may be the best option at least in the short term. Will probably consider replacing when we have the long summer weekends
Trevor
gebrad
Post by gebrad » Wed Jul 26, 2017 9:41 am
I used epoxy before to fix the crack in my washer bottle.
arthuy
Post by arthuy » Wed Jul 26, 2017 11:46 am
I had a split on a bottle in my other car and couldn't find a spare, I just put less water in.
Not an ideal solution but if it doesnt spill out when half full I would do that.
frenchfries
Post by frenchfries » Wed Jul 26, 2017 12:05 pm
I would not bother trying to repair it. It may not work or last, by the time you need another one there won't be any around.
Find on eBay and be done with :)
frenchfries
Post by frenchfries » Tue Aug 22, 2017 2:04 pm
