Sealing the rear lights
Hi there,
There are a few threads where 'rear light seals' are being discussed, my rear lights are glued in win some sort of black waxy glue. I'm guessing this is less than optimal! Does the seal work by pressing the light cluster back into the seal which is like a big rubber 'insole' making for a tighter and more waterproof fit? Any views?
Tim
Tim
Re: Sealing the rear lights
I used this stuff..
http://www.ebay.co.uk/itm/BOLT-ON-PANEL ... 416c8486e8
It seemed to take a while to 'take'. i.e. I had to go back and tighten the screws holding the clusters in a little more as the butyl settled in and spread out. It seems watertight now however and I've had no water ingress for months now. I'd also remove your boot seal and check for rust on the lip of the boot whilst you're there. I found a little and applied rustproof paint to nip it in the bud.
I noticed someone selling proper gaskets on ebay a while back but I think it was just a one off.
I'm sure others will chip in with their suggestions.
Thanks Yorkshire- so you would have popped out your lights and then screws them back into place with the ebay tape forming a seal between the lights & the bodywork?
- jamesy12345
Yorkshire480, I used the same stuff on a leaking ford focus I used to have, on the rear lights, after a recommendation from Ford dealer...
For the 480 I just use a car cover or at least I did til it blew away doh
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Hi used the butyl sealent on my rear lights very little fading after a few weeks one cracked put this down to the light age fifteenth year and the fact that the sealant stop the plastic expanding have some new rear light not fitted them yet but invested in some original style seals foam rubber purchase from V480TI
Yeah...pop out the clusters, clean all the old gasket crap off as best you can with a stanley blade and then recreate them the best you can with the butyl.
Screw the clusters back into position pretty tight and then go back in a day or two and tighten them up again. I'm fairly certain the butyl 'gives' and spreads out a little.
I'd recommend waiting for a warm day (haha - laughable I know at the moment!) as the butyl is softer but mostly because it's shit doing anything in the cold! Get a stool to sit on whilst doing it (my back was killing me by the end!) and take your time. You might also want to apply alcohol internally - to yourself - but that's up to you!
Maybe others have done it the other way round sticking the butyl to the bodywork and then repositioning the the lights over the top?
I used black Sikaflex myself, will probablly be a pain in the ass to get the lights off the car but hey, totally waterproof!
Member V480TI produced perfect seals, they save you fighting the bitumen while mounting and apparently keep the water out. PM him is my advise.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
- AcidicDavey
Yeah I just bought some off of Joep who reproduces selected parts.
They cost about 30€ posted and my car doesn't seem to leak with them on so that's good.
PM me if you want his e-mail.
Thanks guys I will get the bespoke seals then as I am both lazy & bad at diy!
HI there,
I have my set of Joep's seals one for each cluster, but nothing for the middle reflector, is this deliberate, so the water at the base of the bootlid makes its way down under it rather than over the top or siting on the lip at the base of the hatch? Ordo I need an extra bit of foam to seal that bit too?
Best
Tim
Best
Tim
- jamesy12345
Holy thread revival!
Does anyone know if Joep (V480Ti) is still making the seals..?
I've just sent him a mail..
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
James you have a pm remember you left a spare set with me see pm
- jamesy12345
that's great Jim, sent u pm backglasgowjim wrote:James you have a pm remember you left a spare set with me see pm
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- jamesy12345
Joep answered - he is still making the seals as below, also makes one for the part between the two rear clusters...
both photos are Joep's btw
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Want!
Do we just PM Joep direct for these?
- jamesy12345
Sent u a pm with contact details for Joep
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- 89of480
Is it possible to get the PM details for Joep?
I need 2 sets of these gaskets for mine and Dad's leaky lights!
email address removed GJ mod
you can email him direct, I just got a pair of seals of him
'88 Volvo 480 ES
'97 Volvo 940 Turbo
'97 Volvo 940 Turbo
- 89of480
Excellent! Thanks a lot! I'll drop him a line
I've just bought a whole car for spares for 250 so these will seal those shiny lights a treat!
