englemere
Post
by englemere » Wed Feb 28, 2007 1:22 pm
Does anybody else have a problem getting the fabric insert to stay in the door card?
Both my 480's have suffered from them falling off at the back of the door.
Adam
JohnTurbo
Post
by JohnTurbo » Wed Feb 28, 2007 3:52 pm
The holes in the cards fit the clips by friction. A little silicone rubber is a good fix.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
suddy
Post
by suddy » Thu Mar 01, 2007 8:35 pm
i wrap the studs in PTFE thread seal tape. works a treat.
1995 480 S 2.0 237,000 Miles
Post
by pol » Thu Mar 01, 2007 9:53 pm
I use chewing gum.
englemere
Post
by englemere » Fri Mar 02, 2007 1:31 pm
The previous owner had a go with ptfe tape on this, one - i think the holes are now even bigger!
current cure is velcro, works fine unless you're my girlfriend and slam the door shut
Matthew Brennan
- 480 Rookie
Post
by Matthew Brennan » Sat Mar 03, 2007 3:38 pm
Araldite. 12% of my 480 is araldite now. The rest is a mixture of cable ties water and metal
