best glue for the fragile dashboard surround
timrosser
Post by timrosser » Wed Oct 10, 2018 2:31 pm
Hi All,
I was just wondering if any of you have any favourite products for sticking the fragile black dashboard surround back together? I mean superglue is obvious, but I was wondering about using something that could dry mat black or perhaps be sanded to make the repair less visible?
Re: best glue for the fragile dashboard surround
Post by jifflemon » Wed Oct 10, 2018 3:52 pm
I used gorilla glue on the inner dash surround. It's crazy stuff!
Post by Martin Mc » Wed Oct 10, 2018 4:07 pm
I'd second the Gorilla Glue shout to a certain degree, although it is kind of permanent once it is in.. My experience with the fragile surround taught me that the key is to make sure that all of the underlying fascia and supports are fully secured before attempting to re-fit the surround. Unfortunately it is a fact of 480 ownership that the surround will, inevitably, be coming off again at some point in the future.
Good luck with the repairs! I hope it doesn't result in :nuts:
M
