Came up in a conversation today, so I thought I'd share with you. As some of you know, I've a motor trade history, and without sounding all "misty eyed", back in my day, stuff like this was drummed into us before we were let loose on the tyre machine.
On the sidewall of most new tyres are red and yellow painted dots. If these marks are aligned with particular points on the wheel, you can reduce the amount of weight required for balancing. The less lead weight used, the lower the cost of wheel balancing for the garage and the better looking your wheels look.
The Yellow Dot
When tyres are made, they are almost never perfectly balanced, and most manufacturers will place a yellow dot on the section of the tyre where there is least weight. When fitting a tyre, they should line up this yellow dot with the valve stem as this is the heaviest point of the wheel. By aligning the lightest spot on the tyre with the heaviest point on the wheel, the tyre/wheel balance is as close to optimal as can be. So, they'll be fewer weights around the wheel to balance out the tyre and wheel.
The Red Dot
In the same way that tyres are never perfectly balanced from the manufacturer, tyres are never perfectly round either, even when new. They have high and low points which occur where the belts are joined, and these points can cause vibrations when a tyre is rolling. The red dot indicates the tyre’s high point. Sometimes a wheel will also have a dot—either a drilled dot or a sticker to indicate its low point; if you have these marks, you should align the red dot with the mark on the wheel and ignore the yellow dot. By doing this you minimise the vibration caused by the high point of the tyre
Red over Yellow
If both red and yellow dots are visible on your tyre and you don’t have any dots or marks on your wheel, red takes precedence over yellow and the red dot should be aligned with the valve stem. Cancelling out the high point takes precedence over the lightest point of the tyre, which can be addressed with wheel weights.
So, know you now and educate the tyre fitters!
Red Dot? Yellow Dot?
Re: Red Dot? Yellow Dot?
And I thought fitting tyres to aircraft wheels could be awkward.
Well, that's a load of stuff I never knew. I'll bear it in mind in the spring when I replace Lily's tyres - they are still legal but I'm tired of not quite trusting the handling due to having three different brands, two of which I've never heard of. Ditch dumpers I suspect, but they were all practically new when they came with the wheels so I felt obliged to use them. Now I know there is still a market for second hand tyres I'll feel a lot better about binning them.
Ah Chinese death circles, my favourite.....
Be careful what you say Jeff, you might get a present !
Thanks Jeff - I've seen the dots often enough, but never given any thought to what they might mean, so this was all weirdly fascinating
