What is the correct wheel bearing - advice needed
Post by glasgowjim » Fri Dec 09, 2011 4:12 pm
can any forum member please advise on how to get the right bearing for my car.
There is different part no for the bearing on every websites (eurocarparts has different part no than unipartautomotive, also First line catalogue has different part no and ebay sellers have different part no) - but they all list the bearing as it will fit to 2.0 from xxxx to 1995...
I already bought AC pomp that suposed to fit to 2.0 but it didn't....
posted on behalf of another forum member. :)
Re: What is the correct wheel bearing - advice needed
Post by Alan 480 » Sun Dec 18, 2011 12:49 pm
Jim
Can you actually SEE the bearing or are you trying to get the part BEFORE rip wheel off?
If it is a rear wheel bearing the disc/hub comes away VERY easily and you can pull the hub in about thrty minutes start to finish
the nut is NOT that tight!
If you have the bearing in your hand,check the number stamped on the rim and just go to a bEARING supplier?
You have probably thought of this ? :-)
mac0502
Post by mac0502 » Mon Dec 19, 2011 6:07 am
Unfortunately it is a front wheel...and the nut is so thigh. I need a proper wrench handle extension.
I want to do exactly what you said. Take it apart and than check the bearing part no.
But there always problem (like lack of tools to undo tight nut) + I am working on a street so cant leave work at any stage and go home when gets dark..have to put most of things back together.
Also my english isn't very good and don't have much of experience so written guides confuses me.
Zoist
Post by Zoist » Mon Dec 19, 2011 10:55 am
Hi Jim
Can I get the model year, engine name (B20?) and the chassis number? then I can look it up in VADIS for you
this if for a B20F 1995 manual gear R.h.d. with sunroof with chassis 524247- and upwards
mac0502
Post by mac0502 » Mon Dec 19, 2011 11:29 am
Hey Zoist,
the bearing is needed for my 1994 GT, 2.0 petrol, non turbo, manual, B20 F, 588727.
Thanks a lot.
Mac
Zoist
Post by Zoist » Mon Dec 19, 2011 4:28 pm
Hi Mac
I can see that the part no. is the same as in the picture.
#3454197
No problem ;)
mac0502
Post by mac0502 » Tue Dec 20, 2011 4:10 am
Thanks a lot Zoist!
