Damper and springs question.
Posted: Sat Feb 09, 2013 6:51 pm
by yorkshire480
I'm gonna replace my front dampers and have been wondering, is it best practice to replace the springs at the same time? The ride height has always been uneven and I'm sure that one of the springs was replaced at some point and this is the cause.
I'm assuming that replacing both springs will assure an even height on each side.
Thoughts anyone?
Re: Damper and springs question.
Posted: Sat Feb 09, 2013 8:56 pm
by doingitsideways
By uneven, do you mean that one side is higher?
If so, then definitely replace the springs as a pair, the dampers do nothing to alter the ride height.
I'm toying with changing mine too, I recently replaced the rear dampers and it firmed things up no-end
Steve
Posted: Sat Feb 09, 2013 9:13 pm
by yorkshire480
Yup that's right. The distance between the top of the wheel arches and the tyres are slightly different.
Posted: Sat Feb 09, 2013 10:05 pm
by AcidicDavey
If your ride height is different on each side it could be a duff damper, damaged spring etc.
Change both sides and you might as well renew the top mounts too while you're there
