Brake disc backing plates
suddy
Post by suddy » Mon Sep 16, 2013 6:06 pm
Are these brake disc backing plates/splash guards required for the MOT?
Mine are starting to rust away, so how do they attach to the axle? Are they bolted on with the caliper carriers I wonder? I can't see how they are attached to the car...
Kind Regards
Stephen
1995 480 S 2.0 237,000 Miles
doingitsideways
Re: Brake disc backing plates
Post by doingitsideways » Tue Sep 17, 2013 9:32 am
As far as I know, they aren't required. Plenty of cars don't have them at all.
Not too sure how they attach, I would have thought they bolt to the stub axle behind the disc.
Steve :hopping:
Hammers can't fix a 480!!!
suddy
Post by suddy » Wed Sep 18, 2013 11:53 am
I think they are welded on! I cant see any bolts holding them on whatsoever. Going to take the disc off at the weekend and investigate.
Stephen
Post by Alan 480 » Sun Dec 15, 2013 7:11 pm
I made 'new' ones from a piece of galv iron and fixed them to the back plate with the clamps that came with mud-flaps!
I think they are fitted along with the bolts that bolt hub to 'axle'
still to do the front ones as they are almost gone too (well about a third are still there)
I plan to fix them on with the brake caliper bolts, as I have fitted hi tensile new ones as the originals had to be removed with a grinder :cry: I sent SWAMBO to local bolt supplier but the ones that were 'in stock' on the PC had been removed :cry: so had a second trip to rumage thro the store £12 for four :(
