Hi all! My clutch is going out, and i need to change it. Does anyone know if it's alot of work to change it? Me and a friend changed the clutch on his toyota supra, and it was a pretty rough job. Looking at the 480's clutch, it can't be too much work? I mean, it looks like it could be very small, and a easy job to do, but i may be wrong.
So if anyone has a guide\pictures of a clutch-change, it would be much appreciated.
Clutch change
Clutch change
[img]http://home.online.no/~oeys-n/signature.jpg[/img]
--------Use and abuse---------
-1990 Volvo 480 Turbo
-------Used and abused-------
-1988 BMW e34 535i
-1987 Volvo 740 GL
-1985 Subaru 1800 4wd
-1999 Honda NSR 125
-1988 BMW e34 535i
-1987 Volvo 740 GL
-1999 Honda NSR 125
- Bramdeman
its not a small job by any standard. but I've never done a supra so can't really compare. But the 480 turbo is a lot of work. I prefer to lift the whole engine out. But its possible to do it with just dropping the subframe and the gearbox.
If you've never done it before it might be a good idea to get a haynes manual, the whole procedure is in there step by step.
'92 Red ES automatic
'88 340 1,7 Project car
Hmm, done this sort of work many times. We've tried it with the engine in place and its a b*tch to say the least. Getting the clutch aligned and wiggling the box back on is a nightmare
Its a bit of a job, but taking the engine out is the easiest way to do a good job.
You will need - gearbox oil, down pipe gasket, drive shaft roll pins and lot of patience! Good luck Edd
www.teamvolvo.co.uk
www.teamvolvo.co.uk
