Clutch kits- what fits?
VanDerGraaf
Post by VanDerGraaf » Thu Aug 25, 2005 8:24 am
Simple question really- does anyone know if any clutch kits for other cars fit the 480 Turbo (somehow Renault springs to mind).
Rohan
Previously:
'97 Saab 9000 Aero gone
Grey '88 ES dead
Ally
Post by Ally » Thu Aug 25, 2005 9:55 am
Would make sense, wouldn't it... It is a Volvo gearbox though, and in their infinite wisdom they probably made the spline on the input shaft different so you have to buy a specific clutch.
Would be interesting to know though...
480_rocket
Post by 480_rocket » Thu Aug 25, 2005 10:33 am
Turbos got two clutch sizes 200mm and 215mm. There are alternatives from Renaults.
The Renault 5 Turbo for instance is 200mm, but the Volvo one is actually stronger. Then again you can get a lot more options for clutchs on Renault 5s, paddle, organic, sintered etc.
Renault Clio 2.0 16v and Williams came with 200mm or 215mm depending on the year or as I think they call it, 'phase'. Again, quite a few options.
Look for clutchs with 26 splines and 22mm, some prety hefty clutchs here :eek:
http://www.helix-autosport.com/groupa.asp
VanDerGraaf
Post by VanDerGraaf » Thu Aug 25, 2005 10:47 am
Yeah Rocket, this is along the lines of what i was thinking....hmm, options!
Perhaps unwise for a non-techy like me to consider but obviously someone else'd be doing the fitting... ;)
Hmm, paddle clutchs don't seem to last too long.... :(
Previously:
Grey '88 ES dead
robkendall
Post by robkendall » Thu Aug 25, 2005 11:30 am
VanDerGraaf wrote:Hmm, paddle clutchs don't seem to last too long.... :(
much better grip though.....
rgrds
rob
MrE
Post by MrE » Thu Aug 25, 2005 2:48 pm
Ok chaps this what i'm up to right now... Richard's ordered me a kit for the later larger clutch set up. The strongest combination consists of the volvo cover/press plate and a renault williams clio friction disc. Anything else will not cope with large power hikes... ;) hope that clears things up, Edd
www.teamvolvo.co.uk
catgroom
Post by catgroom » Thu Aug 25, 2005 3:22 pm
Indeed Rohan!
I'll 2nd that!
When mine goes to the Burnham School of Box for a good old twitching,it'll be Clio Williams 2 clutch plate,the Volvo cover and a carbon fibre Sachs release bearing.All courtesy of Sachs.£85!Splendid...... :hopping:
I'm No Longer Here :(
VanDerGraaf
Post by VanDerGraaf » Thu Aug 25, 2005 5:54 pm
Groomus, post or pm me the details if you can! Sounds exactly what i was looking for! :D
Previously:
Grey '88 ES dead
MrE
Post by MrE » Fri Aug 26, 2005 7:54 am
Well Groomus there are indeed some mighty fine box's round the burnham area that are currently being dabbled with... ;)
www.teamvolvo.co.uk
chris1roll
Post by chris1roll » Fri Aug 26, 2005 4:03 pm
MrE wrote:Well Groomus there are indeed some mighty fine box's round the burnham area that are currently being dabbled with... ;)
yes...you still haven't explained away the footprint on the 740's windscreen yet :rofl:
JohnTurbo
Post by JohnTurbo » Sun Aug 28, 2005 11:20 pm
Been looking into this, all williams clutches are 200mm. The 'uprated one' from sachs is more likely a 1.8 16v laguna / clio 172 clutch...but god knows.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
alfonzobonzo
Post by alfonzobonzo » Mon Aug 29, 2005 10:17 am
Ally wrote:Would make sense, wouldn't it... It is a Volvo gearbox though, and in their infinite wisdom they probably made the spline on the input shaft different so you have to buy a specific clutch.
The box i just took of my non turbo even has the Renault diamond on the casting. Laguna parts mostly i think.
Alfonz.
Toyota Celica G7 Tsport Storm Blue (LiftTastic)
480 L 1994 2.0 i Metalic Black K&N Panel SOLD (fond memories)
V40 W 2000 1.9 T4 SOLD (kind of miss it)
rpruen
Post by rpruen » Mon Aug 29, 2005 7:09 pm
I don't know for sure yet, but I will find out soon.
I think it may well be a Laguna plate, but as I say I'll find out soon.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
480_rocket
Post by 480_rocket » Fri Sep 02, 2005 12:11 pm
Clio Williams clutch is 200mm, taking 175NM standard
New Clio 172 and 182 are 215mm, taking 200NM standard
Standard B18FT is 175NM
VanDerGraaf
Post by VanDerGraaf » Mon Sep 05, 2005 10:16 pm
So really you could fit a Clio 172/182 clutch and it would be strong enough to take modded tourque then?
Previously:
Grey '88 ES dead
felyx
Post by felyx » Wed Sep 14, 2005 4:00 pm
if you have your old clutch plate you can get them resurfaced in a tougher compand and i did my last 1 at 1.5mm thicker than standard , this cost me £25 cash and they could of reconned the pressure plate and made it 35% stiffer and stronger than standard for £45 this work is done by "FRICTION SERVICES" in warmley bristol, but just look up brake /clutch re lining in your local yellow pages and if your first number can't help they will know somebody who can, and on a huge plus side the company i use is a 24 hour turnaround on clutch plates and 72 hours on strentging the pressure plates.
cheers felyx
