Drive seals
Gapples
Drive seals
Post by Gapples » Thu Oct 05, 2023 1:20 pm
Hi
My 92 480 1.7 is due in for an mot next week
I was just checking oil levels etc and noticed the lhs drive shaft is slightly wet, a small oil weep.
Are these seals easy enough to get hold 🤔 I've had a quick search and couldn't see any, or are they the same as Renault it being a Renault unit ?
It's very little at the moment but I'm guessing it might be picked up as an advisory
Thank you
1992 two tone 1.7
Re: Drive seals
Post by jifflemon » Fri Oct 06, 2023 9:24 am
Exactly the same as Renault one, check the shaft size for the inner bearing though
https://www.ebay.co.uk/itm/235240716593
Gapples
Re: Drive seals
Post by Gapples » Sat Oct 07, 2023 1:18 pm
Thank you
Can I ask what model Renault please 🙏
Thank you very much.
1992 two tone 1.7
Re: Drive seals
Post by Alan 480 » Mon Oct 30, 2023 4:42 pm
Hi
Thank you
Just wipe the drip off the day afore the MoT :D
They seem concerned if it is continuous not just 'damp', otherwise not a single UK built car from the 70's or 80's would pass :rofl:
