Oil in clutch???
Posted: Wed Mar 08, 2017 12:29 pm
Hello,
I'll apologise in advance if this has been covered somewhere but I can't find it covered anywhere and I don't have the time to trawl hundreds of threads. Basically, the clutch in my turbo has been slipping under boost in 3rd (thanks to Robou mod ) so I figured the clutch was on its way out. I trusted you guys on the forum when you said the standard clutch can take it, which I stand by, so I bought a new clutch kit and shipped it off to the garage for replacement. After 4 cringeworthy days of them doing their best to change it they rang up and said it was done but there was an oil leak or 3 from the engine and the oil had leaked down onto the gearbox and had ingressed onto the clutch plate, thus causing it to slip.
I don't have much free time really to play with this as I have a 13 week old daughter, but I will endeavour to sort this lead and/or prevent any leaks getting onto the clutch again. I just wondered if anyone had come across this problem before and what they would recommend; I don't quite understand how oil would get into the gearbox, so is the mechanic wrong about the source of the oil? He recommended steam cleaning but steam plus dodgy old (still functioning) electrics terrifies me! I want to drive the car again but I'm worried that hot oil runs faster than cold oil and therefore don't want to touch it until it has been sorted. I can't afford to write off another clutch, help! Otherwise it's running fantastic
Much appreciated as always,
Swanny
Swanny
