Manual Gearbox Oil Change - Ins and Outs
Laurie945
Re: Manual Gearbox Oil Change - Ins and Outs
Post by Laurie945 » Mon Aug 28, 2023 9:41 am
I'm also a bit confused with gearbox oil choices. The Kroon oil mentioned; is this the right stuff:
https://www.onlinecarparts.co.uk/kroon- ... 11365.html
My synchro isn't 100% either, so I'm desperate to get the oil changed in my '94 GT manual.
F726 OPF - '89 ES 1.7 - Grey
M211 FAD - '94 GT 2.0 - Green
Post by jifflemon » Tue Aug 29, 2023 7:25 am
So firstly, I'd avoid that seller, its a rebranded autodoc site, whom I've had way too many issues with to recommend.
Fri May 18, 2018 10:27 pm
Lots of informative posts here. Special Thanks to Brinkie.
So, reading all the above, my criteria should be :
GL4 ONLY
75W80
Elf NFP or equivalent.
So how about :
https://www.opieoils.co.uk/p-147652-com ... fluid.aspx
Every box above ticked and with VOC discount about £35 for 5L.
It even lists Tranself NFP in the specifications.
That would get my vote but also note this....
Thu May 17, 2018 7:40 am
If you're looking for additional items to add to your basket at Opie, then add some DYNAX S50.... Trust me, you own a 480, you'll need this! :rofl:
:lol:
Laurie945
Post by Laurie945 » Tue Aug 29, 2023 8:10 am
Noted! Thank you kindly. I will take you up on the suggestion. I must have pulled out a kilogram of wet dirt from inside the arches after washing the wheels down 🤣
