I am struggling to find the correct oil for the auto box on my 1995 Celebration. Volvo no longer do it - and cannot at present suggest an alternative.
Having done a google search there are posts which state it is a special oil due to additives?
What is the best oil to use please?
Chris
PS This is what Opie Oils have recommended - The Fuchs ATF 3353, 4000 or 5005 are ideal for that
Auto Gearbox Oil
- doingitsideways
Re: Auto Gearbox Oil
I would have thought Dextron II or better ATF would be fine.
They're not a particularly complex 'box, quite agricultural really compared to modern stuff.
Steve
Steve
Hammers can't fix a 480!!!
Yup, it's Dextron II. Old fashioned but still readily available.
Oh, and I'd stick with Dexron II because you can never empty the box (it retains a few litres). So you'll end up with a mix if you put different or universal (lies) stuff in.
